Emissions Sensor Removal
Old Jul 10, 2017 | 05:03 PM
Dman130's Avatar
Dman130
Here ya go
Originally Posted by matthewq4b
Not in all applications and since the OP never bothered to post a pic and called it a sensor, the only sensor in the exhaust system is the O2 sensor.
Old Jul 10, 2017 | 05:17 PM
Dman130's Avatar
Dman130
Code Removal
I tried the method prescribed and is still running rough, do I need to take it out on the road? It is barely drivable.
Disconnect the battery then turn on the headlights then
turn off head lights reconnect battery, ECU is codes are cleared.
Turning the head lights on off with the battery disconnected with discharge any capacitors in the system that may be holding a charge preventing the ECU from clearing.
Old Jul 10, 2017 | 05:21 PM
vjsimone's Avatar
vjsimone
The 85's were supposed to have the O2 sensor in the Y-pipe like that, but mine has it in the R-Exhaust manifold. Interesting, first 86' I have seen with the O2 in the Y.
Still should not mater much, leave it connected if you can, find another replacement, why not replace it with the same part if you think the Cat has failed?
Old Jul 10, 2017 | 05:23 PM
vjsimone's Avatar
vjsimone
Start it a few times, and take it for a 10 mile run....
Old Jul 10, 2017 | 05:25 PM
matthewq4b's Avatar
matthewq4b
No it should be running fine. Likely something else coincidentally failed.
You will need to pull the codes from the ECU. There are lots of posts on how to do it the search function will pull em up. I cheat and use a reader.
Ford Digital OBD1 Code Reader Scanner EEC-IV Lincoln Mercury Scan Diagnostic Too | eBay
Old Jul 10, 2017 | 05:26 PM
vjsimone's Avatar
vjsimone
Looks like a crimp connection on the O2 wire, that wire has about 0.5v on it.
If it is a crimp, I would remove the crimp and solder in a connector.
Old Jul 10, 2017 | 05:29 PM
Dman130's Avatar
Dman130
Not stock
Who knows what the previous owner did as this is clearly not stock.
Still should not mater much, leave it connected.
Old Jul 10, 2017 | 05:31 PM
Dman130's Avatar
Dman130
Yes it's crimped, I will solder it together if it'll help clear this mess I got myself into
QUOTE=vjsimone;17318756]Looks like a crimp connection on the O2 wire, that wire has about 0.5v on it.
If it is a crimp, I would remove the crimp and solder in a connector.[/QUOTE]
Old Jul 10, 2017 | 05:32 PM
FuzzFace2's Avatar
FuzzFace2
I would try and clear the ECU again and then take it out for a run.
I know the newer stuff has to re-learn to run right and based on what was posted it may be the same on the old stuff too?
In your picture it looks like you can cut the cat off right at the weld and still keep the O2 in place.
I would be temped to grind the weld down so I could pull the cat off and have more pipe to work with.
If you are just removing the cat make a "cat test pipe" to take it's place.
Dave ----
Old Jul 10, 2017 | 05:42 PM
vjsimone's Avatar
vjsimone
[/QUOTE]
Crimp connections under a vehicle don't last very long. This is a 0.0-1.0 v 02 device, single wire, using engine to computer ground. Won't take much corrosion on the crimp, or grounds to knock that voltage down in the lean range.
The tell tail, will be checking the codes, if you get a 41, the O2 connections will be suspect.
Old Jul 10, 2017 | 06:47 PM
matthewq4b's Avatar
matthewq4b
Dave ----
These older systems are not adaptive. There is nothing to learn.
Old Jul 10, 2017 | 07:00 PM
matthewq4b's Avatar
matthewq4b
Crimp connections under a vehicle don't last very long. This is a 0.0-1.0 vdc 02 device, single wire, using engine to computer ground. Won't take much corrosion on the crimp, or grounds to knock that voltage down in the lean range.
The tell tail, will be checking the codes, if you get a 41, the O2 connections will be suspect.[/QUOTE]
It's not a device electrical devices take the energy of electric current and transfor into some other forms of energy
It's a sensor, to specific it's a signal generator it generates a voltage that the ECU measure to ground.
Losing the O2 sensor would not make the truck run like crap it would present some mild driveability problems, it would run rich and blow black smoke and possibly have a hesitation but not run like crap.
And again the OP has not said exactly how the truck is behaving or exactly what running like crap means. It could be anything from vacuum leaks to bad ignition to valve train issues.
So best to quit taking shots in the dark till we have more information.
Old Jul 10, 2017 | 07:38 PM
  #28
Dman130's Avatar
Dman130
My definition of "runs like crap"
It's barely starts and then needs to have slight gas pedal pressure to keep running. It chums, sputters a sounds like it's running on 4cy,l and all mistimed.
So best to quit taking shots in the dark till we have more information.[/QUOTE]
Old Jul 10, 2017 | 08:37 PM
  #29
vjsimone's Avatar
vjsimone
For the older systems, true, 1978-1985
But for the 1986, F150, 5.0L, the Adaptive Strategy was added to the EEC-IV ECA, so not so true.
(The exception to the above, was that the mid-year 1985 F-150 had the 5.0L EFI as an option.
I happen to have one of these at my disposal, (Not by choice), I have had the privilege to cut my teeth, and other parts, on this beast for the past 3 years, with the help of the lads on this post and others. And still only understand 14% of what there is to know.)
Please read "Adaptive Strategy " below;
Old Jul 10, 2017 | 09:11 PM
  #30
vjsimone's Avatar
vjsimone
Agree, we always need more information.
A lot of us use these threads to brainstorm whilst we have the time, even though the OP has not responded, yet, to the last question, it is what it is, nothing to complain about.
There are always a dozen possibilities, or More for an OP’s issue, and with a 30 YO truck, it usually leans towards the More.
Not new to this crowd, when multiple components have failed over time undetected.
I see no “shots in the dark” displayed on these threads.
