*Front End Pulling To Right*
Old Jul 9, 2017 | 10:29 AM
zippi's Avatar
zippi
My 37 pickup is now pulling a little to the right thanks to the bad roads here in southern IN. My question is can I loosen both tie Rod ends and rotate the tie Rod to make a slight adjustment.
Old Jul 9, 2017 | 10:31 AM
zippi's Avatar
zippi
One more pic.
Old Jul 9, 2017 | 03:04 PM
Edd505's Avatar
Edd505
Is it pulling or the steering wheels off? Pulling low tire or alignment issues, moving tie rods moves the steering wheel position.
Old Jul 9, 2017 | 04:04 PM
zippi's Avatar
zippi
It's pulling just a little to the right. Steering wheel is straight and tire pressure is 30 psi on both. It was fine two months ago.
Old Jul 9, 2017 | 04:16 PM
Edd505's Avatar
Edd505
King pins are OK check the alignment
Old Jul 9, 2017 | 07:49 PM
38 coupe's Avatar
38 coupe
Yes, you can adjust your toe-in with the drag link. It looks like your truck has the stock 37-40 drag link. In order to adjust it you have to take one end out of either the passenger side spindle arm or the steering box arm. The 41 drag link is the same width but with the ability to adjust it without disassembling your steering.
Old Jul 9, 2017 | 08:20 PM
zippi's Avatar
zippi
Gotya. So by adjusting the drag link just a little to move both front tires to the left just a little should get me back on track. I'll give it a shot.
Old Jul 10, 2017 | 05:30 AM
bernette's Avatar
bernette
i usely mark the center of the tires tread and measure with a tape.
niko20
Jun 13, 2025 11:48 AM
quakerj
Nov 3, 2014 07:46 PM
cowmilker08
Mar 1, 2010 05:05 PM
Shade
Jun 18, 2009 10:44 PM
gingerbreadmaniac
Aug 6, 2003 10:17 AM
