Need more help on this. Parts stores have no listings for dipstick for 460. We went through all the economies and you can get a pan but not the dipstick.
Need more help on this. Parts stores have no listings for dipstick for 460. We went through all the economies and you can get a pan but not the dipstick. ��
The 460 was swapped into your '78 F150 4WD, because it wasn't there originally.
460 not available with 4WD or M/T until 1983 and then only in F250/350. All 1968/82 460's came with the C6.
Yes, I swapped it in. Then I got a rear sump pan from a friend. You have any part numbers for dipstick assy? All he could bring up were universal push in types, mine is threaded.
I don't have a Ford part number for your dipstick & tube application, because there isn't any.
You'll have to use a universal dipstick, Lokar is one supplier. I don't know who would make a tube, it might be Lokar, might not.
What vehicle did the rear sump pan come from?
I don't have the specs for the dipstick, but 1973/79 F100/350 460 (all 2WD) dipstick tube is 6 19/32" long. 1975/82 E250/350 460 dipstick tube is 28" long.
The Econolines have a very short hood, reaching into the engine compartment, even to access the aircleaner is difficult. So Ford made the dipstick & tube long enough for EZ access.
Open the hood, one of the first things you'll see is the looong dipstick and tube. Something else you'll see, Econolines have a long oil fill tube, it connects to the valve cover w/a curved hose.
FYI, do everything you can to save the original. I got the one from graveyard as it's the only one I could find, it cost me $80. That's more than I paid for 2 rear sump
Pans.
