A/C not working
Old Jul 7, 2017 | 08:05 PM
KDAVID1's Avatar
KDAVID1
A/C not working
Well I suppose it's a good thing I haven't had to post a problem in a long time.
Life has been very busy which sucks.....hate not being active on here.....anyway. It's getting hot here and my account doesn't want to blow cold. I went to add some freon today but it was full (scared I had a leaky condenser) Other than blowing hot it seems the compressor clutch cycles every few seconds and only for a few seconds. Any ideas??
Old Jul 7, 2017 | 10:07 PM
Yahiko's Avatar
Yahiko
Scan to see if the PCM has any stored codes for the A/C system.
Old Jul 8, 2017 | 07:57 AM
Macrosill's Avatar
Macrosill
Do you have a set of gauges? Pressures usually tell the tale on an A/C system. If there are no leaks and the system is not overcharged then maybe the pressure switch went bad?
Old Jul 8, 2017 | 08:12 AM
KDAVID1's Avatar
KDAVID1
Didn't know the ac could throw a code....I don't have gauges but can get that checked. I'll take a look at both. As usual..thanks!
Old Jul 8, 2017 | 08:34 AM
69cj's Avatar
69cj
With out gauges you have no idea wether the freon is full, over filled or low. Cycling could be either low or high head pressure.
Old Jul 8, 2017 | 10:22 AM
KDAVID1's Avatar
KDAVID1
Gotha....was using to gauge on the can....was in range...on the can that is.
When to compressor would cycle it would go to range then back to zero?
Old Jul 8, 2017 | 11:46 AM
Macrosill's Avatar
Macrosill
That gauge on the can attempts to show the low pressure side. I would not trust it much. I did that once and the system started to vent when the compressor turned on. Overcharge and the gauge on the can was in the green.
I just recharged my Suburban. Bought the gauges and vac pump. Changed the receiver/drier and orifice tube. Vac'ed the system, charged based on the proper charge for the vehicle and I am blowing in the low 40 degree range consistently .
Old Jul 8, 2017 | 01:25 PM
KDAVID1's Avatar
KDAVID1
Nice....well I was low on freon. Got a neighborhood buddy to hook is gauges up....he put a can in and it's blowing cold. Now my question is how long it will last. I must have a leak somewhere....for another time I guess.
I do need to get some gauges and a vac pump to do this stuff myself.
Old Jul 8, 2017 | 04:03 PM
Macrosill's Avatar
Macrosill
Cool! No pun intended. lol
It was about 90 today, had the a/c on recirc and it got down to 38 degrees.
Old Jul 8, 2017 | 05:27 PM
KDAVID1's Avatar
KDAVID1
Man I don't think mine has ever been like that.
Guess it pays to vacuum and refill properly. I'll know tomorrow if it still holds.
I'm optimistic.
Old Jul 8, 2017 | 06:14 PM
69cj's Avatar
69cj
Too many people trust the gauges on the self help cans. Some times it works out. Slug a compressor and you'll wish you'd paid a pro. You need to know the low and high side to see what's really happening.
Old Jul 8, 2017 | 09:52 PM
KDAVID1's Avatar
KDAVID1
True....last 2 ac work I had (one a Bronco and the other a tahoe) both cost me 1500 each!
Shoob36
Jul 28, 2017 05:02 PM
jllaco
May 24, 2013 11:27 PM
Muffinman
Aerostar
May 21, 2013 07:14 PM
firedaniel
Sep 24, 2012 06:36 AM
demarpaint
Jul 24, 2004 09:01 PM
