Sponsored by: Auxito
Is this Normal?
Old Jul 5, 2017 | 03:29 PM
Coach_1's Avatar
Coach_1
Is this Normal?
This can't be normal. I was changing out my rear differential seal and u joints today and when I pulled out the rear differential seal I noticed my oil slinger looked bent. I pulled it out and sure enough its bent on the inside of the ring. Is this normal or am I going to have to order a new one?
Old Jul 6, 2017 | 10:09 AM
alloro's Avatar
alloro
Yeah it looks damaged to me. You might want to check the bearings while you're in there. The way that is bent looks like a worn bearing was allowing the shaft to move too far to one side and press on the slinger.
Old Jul 6, 2017 | 10:56 AM
Coach_1's Avatar
Coach_1
I checked the bearings closest to the drive shaft and they seemed ok. Don't really want to tear into the back of the diff but I may have to. Think this is causing my shutter from the rear.
Coach_1
Jul 5, 2017 07:26 PM
tenringdriller
May 31, 2010 10:00 AM
kevin.ford-trucks
May 17, 2008 06:34 PM
Reidicus
Jan 26, 2007 07:40 PM
4604x4
Jul 23, 2002 10:19 AM
