Econoline: Rear A/C question
Old Jul 5, 2017 | 03:18 PM
flosspick's Avatar
flosspick
New to this board and hoping you guys could answer this for me. If I'm using the rear a/c on my econoline and the floor vents are blocked will will heat start to build up from those vents?
Old Jul 28, 2017 | 12:14 PM
lngroller's Avatar
lngroller
my 2009 E350 started doing that. not long after every time I accelerated or climbed a hill my front A/C would default to defrost vents only, did a work around by bypassing the original and adding another vacuum canister and check valve and it fixed both problems
Old Jul 29, 2017 | 08:21 AM
alloro's Avatar
alloro
This is a sign of a vacuum leak. Do a smoke test to find the leak, fix it and everything should work normal again.
ritechous_26
Mar 19, 2013 03:22 PM
AeroStarOwner
Aerostar
May 9, 2012 11:01 AM
mtkstroker2
Dec 17, 2009 10:23 PM
mjwhillock
1978 - 1996 Big Bronco
Dec 6, 2004 06:27 PM
JBronco
Nov 16, 2001 08:50 AM
