no floor heat
Old Dec 17, 2009 | 04:03 PM
mtkstroker2's Avatar
mtkstroker2
no floor heat
I have a 96 F350 PS and I cannot get air to the floor..Everything works that I can find, as in vacuum parts...turn the **** and each one goes in and out..I have defrost, vent but no floor. Thanks ahead for the help
Old Dec 17, 2009 | 04:09 PM
Cuda_jim's Avatar
Cuda_jim
If you have defrost only it's a vacuum leak.
If you have defrost and a little coming out of the vents it's a very small vacuum leak.
If it's not a leak, the blend door actuator may be shot or you have an obstruction in the HVAC box.
This happens when a pencil or the like falls into the defrost ducts.
Old Dec 17, 2009 | 10:23 PM
oldbird1965's Avatar
oldbird1965
My vac line was rubbed by the hood hing on the passenger side and got a hole in it. Replaced that and everything worked again.
djm1204
Jan 20, 2015 12:12 PM
Marks9mm
Jul 4, 2014 07:40 PM
ggadwa
6.7L Power Stroke Diesel
Jan 6, 2013 06:54 AM
rschwab
May 12, 2004 10:38 AM
DCS 03
Oct 4, 2002 12:27 AM
