TFI module question..
Old Jul 5, 2017 | 01:46 PM
Bigblackbastrd's Avatar
Bigblackbastrd
So as far as I know the 93 351w came with a remote mount black module, but for some reason my 93 f250 351w has a remote mount grey module.
Does anyone have some insight on this?
Old Jul 5, 2017 | 01:53 PM
KULTULZ's Avatar
KULTULZ
Question
Both are MOTORCRAFT?
Old Jul 5, 2017 | 01:59 PM
Bigblackbastrd
Yes it's an oem motorcraft product. From what I've read the grey module is a push start module and the black module is a CCD module, but it's also said Ford switched from push start to CCD in 1990-1991.
Old Jul 5, 2017 | 02:09 PM
rla2005's Avatar
rla2005
Ford switched the F-series trucks from Push-Start to CCD ignition in 1994.
1992 and 1993 trucks will use a remote mount gray colored Push-Start ICM. 1991 and earlier trucks use a gray colored distributor mounted Push-Start ICM.
1994 and later trucks use the remote mount black colored CCD style ICM.
Old Jul 6, 2017 | 01:19 AM
_Trekker's Avatar
_Trekker
It took a lot of arguing with my parts guy to get him to realize that there is a difference and that the grey module would not work in the 97 I was working on. It took me installing the module and running it until the CEL came on to get him to find me a black one.
Old Jul 6, 2017 | 07:06 AM
jtmalott's Avatar
jtmalott
Gotta love those guys. Can't tell you how many similar problems I've had with ALL of the local national chain part stores.
Old Jul 6, 2017 | 08:19 AM
rla2005's Avatar
rla2005
The parts counter jockeys are not at fault here. Even Ford's documentation is wrong for this vintage truck. The Lemmings syndrome propagated to the aftermarket as well.
This is a very common issue sad to say. Ask for an Ignition Control Module (ICM) for a 1994-1995 Mustang with a 5L engine. That will make them happy
Old Jul 6, 2017 | 08:01 PM
_Trekker's Avatar
_Trekker
I can verify the ford info being wrong. Ford info says that all ICMs have been superseded to the gray. My problem with it is I told him when I handed it to him that it HAS to be a black one because they are different. Even worse is that he has been in the parts game for 40 years for ford and went through this when they were being replaced like crazy and he still wouldn't listen
CWPottenger
Jul 20, 2012 07:58 AM
macmillanracing
May 29, 2011 01:28 AM
javi2001
Jun 25, 2007 06:57 PM
Alpha7
Aerostar
Jun 20, 2005 12:57 AM
jenglish69
Feb 22, 2002 01:00 PM
