Standerd Vs Reverse timing chain covers
Old Jul 7, 2017 | 12:09 PM
Nothing Special's Avatar
Nothing Special
I don't disagree at all. I will repeat I do not know much about it, but he gave a description of what was different, and everything he described was something to do with the pump, not the timing cover. So why wouldn't a reverse rotation waterpump fit a regular rotation cover? It may indeed not fit, but I haven't seen or heard about the smoking gun yet.
It's been a while so I could be mis-remembering. But from what I do remember, in this picture FuzzFace posted earlier you can see how the two water passages in the cover are angled in for the pump to be spinning CW as you look at the picture. If the pump was spinning the other direction you'd want the passage on the left twisted around so it points across the top of the cover and the passage on the right twisted so it points across the bottom.
Old Jul 7, 2017 | 04:37 PM
Franklin2's Avatar
Franklin2
You are correct. I found this doing a google search.
Old Jul 15, 2017 | 03:39 AM
brake4beaver's Avatar
brake4beaver
Here's another picture of each one, close up it's easy to see the difference.
Standard rotation:
And reverse:
80ford100
Apr 8, 2019 01:57 PM
TheGageinator
Apr 28, 2013 01:21 PM
bearster18
Aug 13, 2012 08:04 AM
bf632
1978 - 1996 Big Bronco
Dec 28, 2004 03:20 PM
siphor84
Oct 22, 2003 03:59 PM
