1978 - 1996 Big Bronco
timing chain cover
Old Dec 28, 2004 | 11:07 AM
bf632's Avatar
bf632
timing chain cover
this question has probably been asked before but... I own a 86' full size bronco with a 351w and just purchased a 351w that is for 87'-96'. most of the timing chain covers for the 87' and up state they are reverse flow, can I use the cover made for the 86' and under or do I have to use the reverse flow for the 87' and up.
Old Dec 28, 2004 | 12:46 PM
greystreak92's Avatar
greystreak92
The difference is in the type of water pump that mounts to it. If the truck has a serpentine belt, the pump is reverse flow, if it still has multiple V-belts then the pump is standard. The timing cover for a reverse flow water pump may not work with a standard pump and vice-versa.
Old Dec 28, 2004 | 03:20 PM
bf632's Avatar
bf632
Thanks for the help!!
