2005
Old Jul 4, 2017 | 07:03 PM
wheelerg's Avatar
wheelerg
I was wondering if the oil pressure gauge would work properly with a different sender. Or is it the gauge that will not read pressure?
Old Jul 4, 2017 | 07:29 PM
HT32BSX115's Avatar
HT32BSX115
Originally Posted by wheelerg
Changed oil from 5w40 to 15w40 synthetic. Now I have a miss from 140 to 160 coolant temp. Probably a bad injector. But I was wondering if the oil pressure gauge would work properly with a different sender. Or is it the gauge that will not read pressure?
Your oil pressure gage reads "normal" over a wide range of actual pressure
AND, I'll also add that 15W-40 synthetic and 5W-40 synthetic are both 40 weight oils
Old Jul 5, 2017 | 09:02 PM
wheelerg's Avatar
wheelerg
Has anybody tried an oil pressure sender off of a vehicle that the gauge actually moves with the oil pressure?
Old Jul 5, 2017 | 09:34 PM
FiznUKa's Avatar
FiznUKa
The oil pressure sensor for the gauge in the dash is only going to read the LPOP not the injector pressure.
Old Jul 5, 2017 | 11:09 PM
wheelerg's Avatar
wheelerg
The LPOP pressure question I was asking , is it the sender or is it the gauge that will not read the pressure as it changes? Every other Ford truck that I have owned has a functioning oil pressure gauge.
Old Jul 5, 2017 | 11:26 PM
FiznUKa's Avatar
FiznUKa
I wish I could answer that question but my guess would be the sender. Can I ask why you would want to know the pressure? I'm curious
Old Jul 6, 2017 | 12:43 AM
87crewdually's Avatar
87crewdually
If I remember right, it was in 1987 that all Ford trucks oil gauge from the factory uses a pressure switch that is only an indicator of pressure above 7psi., not an actual pressure sensor like the older trucks.
There is a mod to use a sensor but I think you also need to modify the cluster on trucks in the 90's.
03-07 Superduties I'm not sure if it has been done or not. Really I don't see the importance because if there is no oil being pumped up to the reservoir for the HPOP it won't run anyways.
Old Jul 6, 2017 | 05:39 AM
bismic's Avatar
bismic
You can add on a pressure sensor and gauge. There is a specific test port for it, or you can mess with adapters to install it where the switch is.
Old Jul 6, 2017 | 09:51 AM
wheelerg's Avatar
wheelerg
Thank you for the info. I am going to add a separate mechanical gauge off my bypass oil filter head.
Old Jul 6, 2017 | 03:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a link to the background of the "idiot Gauge". Fairly entertaining and good info but unfortunately doesn't answer your exact question. I looked around the site a few years ago and didn't find an answer but it would be a good jumping off place if you want to research a bit.
Ford Oil Pressure Gauge Fix
sunogbahay
Aug 18, 2011 03:00 PM
tony b
Nov 6, 2006 12:31 AM
oldgoat49
3.0L V6
Dec 8, 2003 10:34 AM
abendx
Jan 15, 2003 06:15 PM
tomk89xlt
1978 - 1996 Big Bronco
Mar 14, 2001 05:50 PM
