Magnetic drain plug?
Old Jul 7, 2017 | 08:30 AM
mattri's Avatar
mattri
It's the 3.5 NA.
Old Jul 7, 2017 | 09:15 PM
onug's Avatar
onug
So going back to the original question...why not just put a magnet on the outside of the oil filter? Seems like it will accomplish the same thing and not mess with the oil drain plug.
Old Jul 8, 2017 | 06:32 AM
mattri's Avatar
mattri
That would certainly work to a degree.
But why not change out the drain plug to a magnetic one that will stay and catch all of the various ferrous particulate change after change?
Unlike a filter it will be constantly there, always picking up what might be missed.
Old Jul 8, 2017 | 08:45 AM
DOHC's Avatar
DOHC
Inspect the OEM drain plug - it might already use a magnet . However --
From that photo it looks like the drain is above those double lines and other pipe. I would look into a Fumoto drain valve that turns the drain stream straight down just to avoid clean up from splatter time after time. My 6.5 qt Duratec 30 has an easy initial 12 inch or so oil stream drain arc but nothings in it's way to interupt the flow the drain pan.
The magnetic band for the oil filter works well on Allison trans filters so one similar would work around the oil filter.
There is the Magnafilter Magnetic Oil Pre Filter available , but myself, i would use filter bands before that adapter.
Old Jul 8, 2017 | 11:32 AM
KJ Smith's Avatar
KJ Smith
Just an FYI,
My 2011 6.7 had the composite pan and plug.
The alleged benefits were noise reduction and longevity,
Apparently the guys up North with all the road salt liked them.
I think they went back to metal in 2012. Don't know what that says for longevity.
Personally, it didn't bother me at all.
Old Jul 8, 2017 | 03:16 PM
mattri's Avatar
mattri
Been looking around but not finding much for aftermarket options.
Does anyone know what thread/pitch these are?
15mm head fwiw.
Old Jul 13, 2017 | 05:40 PM
mattri's Avatar
mattri
Sorry for late reply but Dorman 65212 fit just fine. Same head diameter, same thread/pitch (obviously) and is magnetic.
Cost about $2 at local O'reileys.
MG250
6.7L Power Stroke Diesel
37
Dec 29, 2020 09:54 PM
A/Ox4
30
Jul 14, 2019 10:26 AM
jonrjen
26
Mar 31, 2014 07:44 AM
superduty4x4
Aug 1, 2008 08:27 PM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
