My 2017 H.O. Ecoboost has a plastic drain plug and a plastic oil pan. You only turn the plug 1/4 turn to remove it and re-install it. I'm not sure if it's just the Ecoboosts that have this?? I've done 2 oil changes so far. I'm not real crazy about the idea but I doubt I'll have any issues with it. I'll just change the o-ring every so often.
I'm pretty sure there aren't any aftermarket magnetic replacements yet.
When I did my first oil change. The re installment of that cap seemed sketchy to me. I did not seem secure.
I was so used to wrenching drain plugs on.
Heh. Same here. I've only done one oil change so far, but I was really paranoid about that plug coming loose or just popping out all together. I think I was sticking my head underneath after every drive for the whole first month making sure it was still on right.
Anyway, while it doesn't feel secure compared to a screw-in steel bolt, it certainly seems to be.
Also, has anyone bought one of the aftermarket plugs on Amazon? I was thinking for the $10 or so, it would be good insurance to keep a spare in the toolbox.
It seems there are a few manufacturers though, and I'm unsure of quality. If anyone has experience with any of them, I'd sure be interested in hearing opinions.
I'd like to know if it is truly plastic or a composite material. And I'd like to have a word with the engineer that chose the material. I know cost and weight are factors in everything...but come on...the bottom of the pan exposed to the road?
What about for those who go off road, either trails or have to go into road construction areas? Hit a stump or rock just right and there goes your engine. Sure if the metal skid plates can go back far enough to protect it that's once thing, but an open pan, not a chance.
Could one epoxy a magnet to the drain plug to accomplish the same thing rather than look for a steel plug that might ruin the plastic/composite pan?
