I was looking at the towing selector, and on the the page with MAXIMUM CARGO WEIGHT WITH SLIDE-IN CAMPER, I see two identical lines in the chart. I have clipped a picture.
I will be towing a fifth wheel, but I assume that cargo weight includes pin weight for the trailer too. I want the maximum.
The difference between the two is 240 lbs. Can anyone tell me what the equipment difference between the two lines is? Maybe a misprint?
The best I can figure out is that there's a typo. Specifically, the third configuration line should apply to the 176" crewcab longbed model (11,300 GVWR w/ 6.2 and 18" A/S tires) instead of the 159.8" crewcab shortbed (10,900 GVWR w/ 6.2).
