HELP
Old Jun 26, 2017 | 09:41 PM
virgin destroyer's Avatar
virgin destroyer
HELP
I've got a 72 E-100 van . I need to fix the side slider assembly but I cant figure out how to remove the outside panel that exposes the rail and arm .I removed the 2 screws ,1 inside and the one up under the back corner . I can't see any other screws . Any help would be great . THANKS in advance .
Old Jun 27, 2017 | 06:18 PM
Wildman25's Avatar
Wildman25
Pry/pull it straight forward, it slides over several studs, in a "key hole" type set up.
Old Jun 27, 2017 | 06:38 PM
virgin destroyer
Cool thanks I'll give it a try .I just hate to bend it , that thing seems tighter than 2 D's in an R .
Old Jun 27, 2017 | 08:37 PM
virgin destroyer
It won't slide forward ,there's a bracket at each end . It appears it can only come straight out or up and out ? I wonder if there's screws on the inside ? I hope not interior is cherry (fur and vinyl)I think I would destroy it taking it out .
Old Jun 28, 2017 | 12:54 PM
wiskeyVI's Avatar
wiskeyVI
I've not had to deal with those....
Old Jun 28, 2017 | 03:45 PM
jimbomitch's Avatar
jimbomitch
More than likely there are fasteners inside the van that are holding it.
Old Jun 28, 2017 | 08:45 PM
Wildman25's Avatar
Wildman25
Yea, should be one Phillips screw at the rear, inside the cover, and one at the door jamb, inside the slider.
Thought I read in your OP that you removed the screws??
Pulled those screws, and it should slid forward of the key slots.
Note.......been 12 years since I had to deal with repairing a slider.......cube vans don't have sliding doors
Old Jul 5, 2017 | 07:42 PM
virgin destroyer
Thanks for the input guys . It had 5 screws holding it on inside . Destroyed panel removing but got the slider to work like new .
Budlight592
6.7L Power Stroke Diesel
Feb 28, 2012 09:41 AM
F-250 Super Duty
Feb 28, 2011 01:48 PM
Bladely
Jan 10, 2010 04:08 PM
Black MI
Sep 22, 2008 08:41 PM
Backin72
Sep 6, 2004 06:55 PM
