I took out the two 10mm screws holding it in and started to pull on it. It's not coming out. Am I missing something? I just didn't want to pull too hard and break something so I figured I'd ask first.
Getting ready for the 650 lower dash panel!
Walt has you covered.
You can remove the drawer without un-screwing the bracket so you might try that. There are little plastic stop tabs (2) that keep the drawer from sliding all the way out. You can use a thin screw driver to depress those tabs to remove the drawer. With that removed, you can see those two screws quite easily.
(still easier to access via the ashtray/bag holder cavity though....I was able to reach the screws through the drawer slot but it was tough.)
