I carry a Ingersoll Rand W7150 with me at all times if I'm going further than work. It is absolutely amazing for changing a flat. Second most important thing is a good bottle jack.
20 volts
780 lbs/ft
2300 beats per min
I use an electric craftsman impact and it works just fine for me.
Originally Posted by Just Strokin
I have one of the Craftsman 19.2 volt impact wrenches. Like stated above, I break them loose with long 1/2 ratchet and then torque them with 1/2 drive torque wrench i carry. I use the 19.2 XCP lithium ion batteries with mine. I carry a lithium charger in the truck that i can plug into the console 120vac.
Same here, relatively low investment and works for 99% of what I need it to do. Other than that, it would be nice to have a cordless jack....
What's the deal with the batteries though? Everything I buy that uses them, they don't seem to last too well. I think they are Ni-cad? I found out about a way to zap them with a high voltage electrolytic when they won't take a charge anymore, and it does work well but seems temporary. I saw some replacement batts at the hardware store the other day and they wanted $70, for one (1) battery. Sure that's retail but jeeze louise.
Ted, if possible replace your nicads with lithium - they seem to last forever - you will never go back to nicad. I did this with my 18v Dewalt tools. Hth.
