Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Impact Torque Rating?
Old Apr 27, 2008 | 08:41 PM
Lariat#1's Avatar
Lariat#1
Question Impact Torque Rating?
What is the least in Ft. Lbs. the torque need to be for removing & installing lug nuts on our F150`s???I just bought a 400 Ft. Lb impact is that enough??
Lariat#1
Old Apr 27, 2008 | 09:18 PM
Ford_Six's Avatar
Ford_Six
That should do the job. If you have a newer truck with the flat washer lugs, you MUST torque them to the spec in your owners manual or you could loose the wheel or damage something. It's not a bad idea to put lugs on by hand and torque them regardless of wheel type, though.
