AC system
Old Jun 27, 2017 | 04:08 AM
Yahiko's Avatar
Yahiko
Pt2
Old Jun 27, 2017 | 04:20 AM
Yahiko's Avatar
Yahiko
Pt3
Well it seems that FTE is having issues with uploads.
I have 15 more files to go and will have to wait to finish.
Old Jun 27, 2017 | 04:47 AM
Yahiko's Avatar
Yahiko
Pt 4
Well that should do it unless I missed something. If I did let me know.
Old Jun 27, 2017 | 05:39 AM
VictorwithaC's Avatar
VictorwithaC
Originally Posted by Yahiko
Pt 4
thanks so much man it won't let me rep you again but know it is appreciated.
Old Jun 27, 2017 | 05:54 PM
Yahiko's Avatar
Yahiko
Your very welcome.
Let me know if I missed something or you need other info.
Also like I said U nay of uploaded some duplicates with s
different name on them. Lots of things to read. Some things
are very short 1 page things like most of the 412-00 stuff.
Old Jun 27, 2017 | 06:46 PM
69cj's Avatar
69cj
Your very welcome.
Dam Sean, if you can't baffle them with BullSh**t do it with paper work. Just joking. LOL.
Old Jun 27, 2017 | 08:14 PM
Yahiko's Avatar
Yahiko
I have to say it surprised me on the amount once I was done.
Old Jul 5, 2017 | 05:06 PM
VictorwithaC
So new parts in regular AC works great. However, my AC short cycles on max ac. Any thoughts?? Replaced dryer, condensor, and orifice tube.
Old Jul 5, 2017 | 06:42 PM
Yahiko's Avatar
Yahiko
I had a reply all done and went and lost it.
I am not very well versed in A/C but it sounds like a pressure
issue going on. The system will shut down on a HIGH or a LOW.
Time for an A/C manifold gauge set and some knowledge.
You should be able to pull some DTCs from the system.
Most of the auto part stores can't read the Ford specific DTC set
very well if at all. The app for the ELM device FORScan should
be able to read any DTCs stored by A/C system faults. Also
if you have the EACT you can read some of the codes in it's display.
Found the info on the EACT self test.
https://www.ford-trucks.com/forums/1...nd-shakes.html
Originally posted by member RobertA from explorerforum.com
”Listed below is the EATC Module Self Test instructions that I followed. Also, if you don't have an
actuator from the dealer, I recommend to get one. The one that I got from Doorman did not work
for me nor for a colleague of mine.
By the way the DTC code that I got from running this test was 025, which is Intermittent Run - time
Fault for hte Blend door actuator. You might also get a DTC code of 024, which is Self-Test Fault for
the blend door actuator. If there is a fault a three digit number will be displayed where the temperature
is usually displayed on the ATC. Good Luck
• lThe EATC module self-test will not detect concerns associated with data link messages like engine c
oolant temperature or vehicle speed signals. A NGS tester must be used to retrieve these concerns.
• The EATC module self-test will detect concerns in the system control functions and will display
hard Diagnostic Trouble Codes (DTC) in addition to intermittent diagnostic trouble codes for concerns
that occur during system operation. The vehicle interior temperature should be between 4º-32ºC (40-90ºF)
when performing the self-test. If the temperatures are not within the specified ranges, false
in-car temperature sensor DTCs will be displayed.
• The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
• To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the
AUTOMATIC button within two seconds. The display will show a pulse tracer going around the
center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
• If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
• If a condition exists but no DTCs appear during the self-test, refer to the Symptom
Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
• To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control
will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
• To exit self-test and clear all diagnostic trouble codes, press the DEFROST button. The vacuum
fluorescent display window will show 888 and all function symbols for one second. Then, the EATC
control assembly will turn OFF (display blank) and all DTCs will be cleared.
• Always exit the self-test before powering the system down (system turned OFF).
• Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.”
I hope that this info helps you out.
If not I would find someone that knows more about A/C systems in automobiles.
Old Jul 5, 2017 | 06:47 PM
VictorwithaC
I unfortunately dont have the "smart" ac controls they talk about to do the self test. My system is running perfectly fine just not working correctly in max ac. I'm wondering if its maybe a blend door issue. My valve on the coolant line shuts fine. I guess ill roll on normal ac till I get a minute to fool with it. Thanks for tbe quick response was hoping someone could give the magic this is tbe issue but no worries at least she works lol.
Old Jul 5, 2017 | 06:54 PM
VictorwithaC
Real quick also "max ac" is just recirculation of cabin air yes? Where does it physically pull from? I wonder if I have an actual clog somewhere. And do we have a cabin air filter in these trucks and if so where or is there somewhere specific it draws air in I could clean? Just thinking of possibilities
Old Jul 6, 2017 | 03:31 AM
Yahiko's Avatar
Yahiko
Not sure on the where.
But I think your correct that is just recalculation of cabin air.
Old Jul 6, 2017 | 09:09 AM
  #28
VictorwithaC
we dont have a cabin air filter do we?
Old Jul 6, 2017 | 09:16 AM
  #29
Per4mance's Avatar
Per4mance
No cabin filter
Old Jul 6, 2017 | 09:20 AM
  #30
VictorwithaC
Originally Posted by Per4mance
No cabin filter
ok thanks. I just talked to my guy and it short cycles bad in max ac but no issues in ac so not a charge issue but we are gonna throw gauges back on it at lunch with it in high idle to check pressures just to be sure. I'm also just gonna replace the controls maybe that will help.
