Can anyone clarify where this wire should go?
Good day all.
Found some time to work on the 66 today. Still cleaning up some electrical demons from PO.
I have this fat green and red wire coming through the firewall grommet with the wires for the amp meter gauge.
Inside the cab it just dangles not connected to anything and obviously cut from engine bay side.
Can anyone tell me where or what this wire does?
Thanks,
Aaron
Thanks,
Aaron
I recently took apart two of those C5TA-10A665-C harnesses. In order to run some extra wires in one for my Neutral safety switch. Both of them had that green wire in them and it had been cut off and taped over in both of them. I suspect that harness was used in other larger trucks that had some other sensor wired in that our trucks don't have.
Good day all.
Thanks,
Aaron
Thanks,
Aaron
1965/66 F100/250 2WD & F350; 1966 F100 4WD
Green/Red Mystery
Seems like we have at least three harnesses here that the green/red wire has been neatly cut out of. And the remains left in the loom. In both of my harnesses that wire would have exited the harness about the middle of the firewall right behind the engine. Could it have been they made a change in the harness and instead of redoing them they just cut the wire out.
