I assume factory remote start was available on these trucks- curious as to what package it came in and/or what trims it was available on? Just wondering if there's a way to know "at a glance" so to speak.
It is actually available with all trucks, just needs to be turned on which you can use forscan. You don't need to add anything except a key to control it. The range will be poor so you should add the antenna. That is all you need.
Check my signature for the forscan spreadsheet and how to info for forscan.
