Add Factory Remote Start
Old Nov 30, 2017 | 07:56 AM
Mascioni's Avatar
Mascioni
Hi everyone just need some advice on how to add factory remote start, should have ordered when I ordered the truck 2017 F250 Super Duty. Any advice would be appreciated thanks in advance.
Old Nov 30, 2017 | 09:04 AM
RCR70ss's Avatar
RCR70ss
Lots of posts already on this subject, just do a search and grab a beer.
Old Dec 2, 2017 | 07:40 AM
Joel Wiedeman's Avatar
Joel Wiedeman
https://www.12volt.solutions/
Look at their setup. I just got one for my '17 CCSB 6.2L. I only use the factory 3 button key fob. Easy to install and no extra key fob. 1/2 the cost of a OEM unit.
If you get one please tell them i referred you.
Old Dec 2, 2017 | 08:35 AM
Mascioni's Avatar
Mascioni
Hey Joel thanks for the response that's all I was looking for I'll definitely let them know you sent me have a good day thanks Yokai
Old Dec 2, 2017 | 09:01 AM
Poncho450's Avatar
Poncho450
There's a thread or 2 on the 12 Volt Solutions setup also. Some guys were happy with it, some were not.
I'd check into it further before blindly buying.
Old Dec 2, 2017 | 09:10 AM
Pocket's Avatar
Pocket
Just FYI..... "Factory" remote start is on the key, and Ford does not offer a kit to add remote start on the key outside of production.
Ford does offer vehicle security/remote start systems for your truck in a couple of flavors. The standard long-range one-way remote start/vehicle security system is the following 2 part numbers:
FT4Z-19A361-A
EL3Z-19G364-B
You can also get bi-directional remote start where the FOB will beep and flash to confirm a successful start. Or you can also get Remote Access to remote start your truck from your cell phone. The remote access modules are being phased out for a more expensive system being released soon.
Old Dec 2, 2017 | 09:17 AM
Poncho450's Avatar
Poncho450
FT4Z-19A361-A
EL3Z-19G364-B
I've got the FT4Z-19A361A coming along with a DL3Z-19A390B for my 2017. I was sure that I read that the second part will work on 2017s.
Did I order the wrong RMU?
Old Dec 2, 2017 | 09:18 AM
Pocket's Avatar
Pocket
You have the correct numbers, and yes it will work just fine.
The part numbers I posted was basic one-way remote start, not the Remote Access RMU.
Old Dec 2, 2017 | 09:22 AM
Poncho450's Avatar
Poncho450
Thanks. Will have to search out a bidirectional fob once everything is here for those times that I don't have the phone handy.
I also installed a longer range antenna in my last truck but was told that it isn't always necessary.
Old Dec 3, 2017 | 06:21 PM
Dtabet01's Avatar
Dtabet01
I have the 12vsolutions remote start kit on my '17 6.7 and it works flawlessly. Takes a few extra seconds to initialize and actually start the truck than the factory setup but nothing I feel I can gripe about. Extremely easy to install I might add.
pdombrowicki
6.4L Power Stroke Diesel
23
Sep 16, 2021 10:00 AM
jdunk54nl
Feb 22, 2021 02:46 PM
moynihan1129
Aug 15, 2018 07:41 AM
ghunt
2009 - 2014 F150
Nov 21, 2017 09:30 AM
mpally
2009 - 2014 F150
Dec 6, 2012 07:46 PM
