Reconnecting a removed compressor
Old Sep 4, 2003 | 10:24 PM
STUDENT's Avatar
STUDENT
I have a 1981 F-150. I bought it 4 years ago for my son. When I bought it the r-12 system worked,not well,but it worked. After about a year it really didn't seem to do much at all. I told my son we'd get it fixed, but he was 17 and much smarter than me. So he decided to take it off all together since it was robbing him of important horse power. Not just from the belt but also the weight of the compressor. Well about 2 years ago he tragically lost his mind and bought a Cheby. Instead of letting him sell the Ford, I just took it back from him. This past Texas summer has gotten me wanting to hook the A/c back up. What do you think the odds are that the compressor is still good . and what parts do you recomend replacing to convert it to a 134 system.
By the way when he took the compressor off he said it spewed freon for quite a while so I guess it still worked back then with no real serious leaks.
Old Sep 4, 2003 | 10:47 PM
Ultramagdan's Avatar
Ultramagdan
Long odds on a old system that has now been exposed to the elements (humidty). That freon was worth something even 3 years ago. So he vented $ to the atmosphere and I'm not going go into the rules about venting R12 into the air.
You will need to do a proper conversion and pull vacuum on the system for a extended period of time to make sure all the moisture is out.
When he opened the system 3 years ago, all the components were compromised. 3 years has made it that much worse.
How bad do you want AC?
Old Sep 4, 2003 | 11:18 PM
STUDENT's Avatar
STUDENT
What exactly is a proper conversion? I know the dryer needs replaced and some fittings to convert to 134. What else is suggested. I've heard of flushing the system. is this something I could do or does it really even need to be done.
How bad do I want AC? The older and fatter I get the more important it's becoming. But then if it costs too much, I guess I'll just have to lose weight and and get younger somehow.
Old Sep 5, 2003 | 12:15 AM
michaeld6638's Avatar
michaeld6638
Well if it's been open...umm well EVERYTHING needs replacing. Condenser, evaporator, dryer, compressor, hoses, everything. Get it all done and you won't have to worry about it for a long time.
Old Sep 5, 2003 | 06:34 AM
94van's Avatar
94van
For the proper conversion proceedures, go to: http://www.ackits.com/forum/categories.cfm?catid=17
and read the suggestions, plus the other worthwhile information posted.
Old Sep 5, 2003 | 09:10 AM
94van's Avatar
94van
STUDENT
Here is what I'd do if it was mine;
Flush the entire system with mineral spirits as per accepted standards.
Replace all the old o-rings/seals with new.
Replace the accumulator/drier.
Flush the compressor with the proper oil (not solvent) and install the proper amount of oil.
Install the rest of the required oil in the system.
Pull a 29" vacuum for an hour or so, let it sit for a few hours and determine if there are no leaks.
If no leaks, install required R-134 using a good manifold gauge set.
Santimanzano
Mar 18, 2018 08:05 PM
mytoolman
Oct 18, 2016 12:48 PM
Dave_Expe
Aug 31, 2016 02:50 PM
jtlinn1975
Garage & Workshop
Jun 25, 2014 11:43 AM
poffutt
Mar 7, 2005 02:50 PM
