trailer delete
Old Jun 21, 2017 | 10:14 PM
KWDAILYD's Avatar
KWDAILYD
trailer delete
I know I've seen this discussed but I did a search and couldn't find it. When I disconnect my trailer it still shows miles being applied to trailer. Everything else in the dash says no trailer connected. I deleted the trailer to stop it. Is this what you have to do every time you disconnect the trailer then reconfigure it again? For the life of me I could not find an option to just stop the miles being applied to the trailer. Hope I'm just missing something and someone can steer me in the right direction.
F350 KR 6.7 CCSB
Old Jun 21, 2017 | 10:24 PM
Tricon's Avatar
Tricon
You have to go in and select no trailer as the current trailer. If this is selected and it's still racking up miles then you have a different problem.
Old Jun 21, 2017 | 10:46 PM
KWDAILYD's Avatar
KWDAILYD
I'll try that thanks. didn't see that option but I'll look again
Old Jun 22, 2017 | 12:10 AM
eazmo's Avatar
eazmo
I also have to select no trailer. Is this new for 17? My 16 would do it automatically when i unhooked????
Old Jun 22, 2017 | 01:08 AM
Tricon's Avatar
Tricon
It's a bug. It works for me 90% of the time. But sometimes I have to manually unselect the trailer.
Old Jun 22, 2017 | 10:29 AM
KidAutolite's Avatar
KidAutolite
TRAILER ODOMETER
When you select "No Active Trailer".
You also have to put your foot on the brake!
Old Jun 22, 2017 | 10:36 AM
K A M's Avatar
K A M
Do you have a adaptor still plugged into the truck? No trailer connected means that you have a trailer selected and it's not sensing a trailer connected. Do not delete trailer unless your no longer have that trailer. Go to the trailer selection and select trailer, then NO ACTIVE TRAILER. This will turn it off but you have to be stopped to do this you cannot be driving.
Old Jun 22, 2017 | 12:29 PM
natpark's Avatar
natpark
Go into your trailer screen, select "trailer set up", then select "No Active Trailer". I have to do this every time I unhitch. "No Active Trailer" is the only trailer in the list if you have not set up any trailers, just FYI.
srkr
May 3, 2025 04:02 PM
bigwin56f100
15
Oct 9, 2017 01:58 PM
Spode
May 17, 2017 11:10 PM
gman97005
General Automotive Discussion
Feb 2, 2016 12:03 AM
