radiator support help
Old Feb 4, 2013 | 09:10 AM
blacburn10's Avatar
blacburn10
Hey guys i'm currently restoring a 65 f100 and my radiator support is trash however I found one relatively cheap but its off a 67 would it still work?
Old Feb 4, 2013 | 11:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No, 1967 (1967/72) is a different body. There are TWO different 1967/72 F100/350 radiator supports that will not interchange with each other. So neither will work on anything 1966 and older.
1965 F100/250 2WD is the same radiator support as 1966 F100 4WD: C6TZ-16138-C = Obsolete, not reproduced.
1965 F100/250 4WD radiator support is the same as 1961/64 F100/250 2WD/4WD, 1961/66 F350/600, 1966 F250 4WD: C2TZ-16138-G = Reproduced.
1966 F100/250 2WD: C6TZ-16138-B = Reproduced.
Old Feb 4, 2013 | 12:07 PM
camperspecial65's Avatar
camperspecial65
PM me blackburn...I have one..or leave a visitor message with contact info..
- cs65
Old Feb 4, 2013 | 01:04 PM
blacburn10's Avatar
blacburn10
So would i just be better off trying to repair it? it's not completely scrap just would take a major repair,as i'm doing what i can with each paycheck
thanks let me know-RB
Old Feb 4, 2013 | 02:23 PM
66with352's Avatar
66with352
I know it's been posted a thousand times, but....What exactly needs to be done for a 65 f100 4x4 rad support to accommodate a 66 f100 4x4? Is it just the radiator brackets and a hole for battery tray ?
Old Feb 5, 2013 | 05:41 AM
camperspecial65
the 65 F100 4WD as well as F250 4WD use the same support as all 61-64 F100-350 trucks 2 and 4WD. the 66 F100 4WD uses the same support as the 65 F100-250 2WD...angled fender aprons, different battery tray and different radiator mounting setup...the 65 F100 4WD has the curved fender aprons for one thing and I think the radiator mounting is different and theres no accomodation for a battery tray as all 4WD except the 66 F100 4WD has the battery monted in the carrier outboard of the passenger side frame rail under the RH floor of the cab.
- cs65
Old Feb 5, 2013 | 08:55 AM
schoo's Avatar
schoo
Have radiator support (65')in nor cal with inner fenders
Has some rust but repairable
1961 f100 4x4
WTB - Parts & other
Oct 5, 2015 05:13 AM
The Masked Rider
Nov 19, 2014 11:21 AM
624WD
Oct 1, 2014 11:57 AM
Shadowrider123
Jul 5, 2014 04:14 PM
kylejhowe
Aug 25, 2010 07:41 PM
