hey guys,
so i have a question about replacement core supports. i cant seem to find one for my 66 f100. i find them for other years or for 4 wheel drives but none for my 66 2wd. i found a repro for a 61-64 that says will fit with cutting off a bracket and drilling some holes. does anyone know if this is true? i want to start pulling apart my front end but i dont want to reassemble without all the parts. any help is appreciated guys.
thanks
1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD
-------------------------------------------------------------------------------------- C6TZ-16138-B .. Radiator Support / According to some members of this forum, recently reproduced, available from LMC
1966 F100/250 2WD
-------------------- C6TZ-16138-C .. Radiator Support / Obsolete
I purchased the core support repro from LMC Truck several years back, and it does fit, but you will need to modify a bit. Nothing too drastic, but an actual '66 core support will save you some time.
Time i have, thanks a lot guys. I appreciate the help. Im just happy to know i can get this thing rolling without having to buy a parts truck. They're hard to come by in new england
The core support from 65 to 79 will bolt up, will not cost 300$.
Where in the hell did you get this crap info? There is no way, none .. that any 1967/79 core support will bolt up to any 1965/66.
1965/79 F100/350: There are EIGHT different core supports.
1965 F100/250 2WD, 1966 F100 4WD use a different core support (C6TZ-16138-C) than 1966 F100/250 2WD (C6TZ-16138-B), because the radiator flanges are in a different location.
1965 F100/250 4WD, 1965/66 F350/600 & 1966 F250 4WD use a different radiator support (C2TZ-16138-G) than either of the above.
1967/72 F100/350: There are twodifferent radiator supports: C7TZ-16138-A & C7TZ-16138-B
C7TZ-16138-B was only used with the Super Cooling radiator, because this radiator is taller than the other radiators and so...the support has a larger opening radius.
D3TZ-16138-B has two sets of mounting holes and a larger opening radius, was only used with the Super Cooling radiator that is taller than the other radiators.
1978/79 F100/350 with rectangular headlamps: D8TZ-16138-A = Core support is dished inwards behind where the headlamp buckets mount.
