Window leaking
Old Jun 17, 2017 | 05:59 PM
VanGuySteve's Avatar
VanGuySteve
Window leaking
Anyone seen any information on fixing a leak in one of these top windows?
It's the window seen here on the roof.
Old Jun 18, 2017 | 02:16 AM
vettex2's Avatar
vettex2
I'd use clear silicone
Old Jun 18, 2017 | 03:42 AM
kaz442's Avatar
kaz442
I wouldn't use silicone do to the fact it's not UV resistant and will fail over time and then nothing will stick to the area including silicone. I would use 3M 4000uv, it's a marine caulk and adhesive. It's designed for bedding cleats and such on boats and it's UV resistant. It comes in white or black. Or you could see if the window is removable, mabye remove the inside trim to see if there are screws . Then I would reinstall it with some double-sided eterna bond tape. Of course this will only work if it is removable.
Old Jun 18, 2017 | 07:03 AM
jayro88's Avatar
jayro88
Can you get behind the lip of the seal? They make flowable silicone that you can use to seal up in behind the seals.....if that's where it is leaking from. I would first try and verify the leak location prior to attacking the seals.
Old Jun 18, 2017 | 03:12 PM
vettex2's Avatar
vettex2
I've used clear silicone and it lasted 10+ years until I got rid of my old van.
Old Jun 18, 2017 | 08:20 PM
annaleigh's Avatar
annaleigh
I had this problem on my van with the same top as yours...
here is the thread about it
https://www.ford-trucks.com/forums/1...s-leaking.html
Here the molding is called Trim-loc
https://www.trimlok.com/rubber-extrusion/locking-gasket
It appears that the pics are gone so here is some more..
HEre is a pic of one of my windows
Here is a pic of the inside trim.Notice the little metal clips atound the inner edge. They hold the trim to the window. They are cliped in underneath the seal
here is a close up with the trim pulled partially out
Look at the left window and you will see a bludge wehre the insert is not all the way in
This is another pic from the inside.
oldstylefseries
1997 - 2003 F150
Sep 2, 2008 05:03 PM
johnw
1997 - 2003 F150
Apr 24, 2005 02:35 PM
Cape Guy
1997 - 2003 F150
Oct 30, 2004 10:38 AM
mendeldl
Aerostar
Jul 12, 2004 12:51 PM
fishman5758
1997 - 2003 F150
13
Nov 21, 2003 10:21 PM
