2018 Engine numbers released
Old Jun 15, 2017 | 01:32 PM
92F350CC's Avatar
92F350CC
2018 Ford F-150 and Expedition getting powertrain upgrades
Changes for the 2018 F-150 are as follows:
          All engines get standard stop/start technology.
          The 5.0 numbers are a bit underwhelming IMO, but it will be interesting to see the fuel economy.
          Old Jun 15, 2017 | 02:20 PM
          duckduke's Avatar
          duckduke
          Thanks........ I've been checking here and online almost daily!!
          Now:
          F150 5.0L....... 395 HP /400 ftlb....... 10 speed tranny
          F250 6.2L....... 385 HP/430 ftlb ........6 speed tranny
          Which one???
          Old Jun 15, 2017 | 02:25 PM
          duckduke's Avatar
          duckduke
          Here are the #'s from the Ford web site:
          NEW ENGINE OPTIONS
          Based on your need, the 2018 F-150 provides more engine alternatives all paired with a 10-speed transmission to deliver improved acceleration and performance.
          - All-new standard 3.3L Ti-VCT V6 – 290 HP/265 lb.-ft./rpm
          - 2.7L EcoBoost® - 325 HP/400 lb.-ft./rpm
          - 5.0L Ti-VCT V8 - 385 HP/397 lb.-ft./rpm
          - 3.5L EcoBoost - 375 HP/470 lb.-ft./rpm
          - High-output 3.5L EcoBoost (on F-150 Raptor) - 450 HP/510 lb.-ft./rpm
          Also look for yet another powerful new option… with a new 3.0L Power Stroke® Diesel engine. Coming in Spring 2018.
          Old Jun 15, 2017 | 02:52 PM
          xr7gt390's Avatar
          xr7gt390
          Now:
          Which one???
          The Super Duty Trucks use a different method for determining HP and Torque than the F150. If the 5.0 was in the Super Duty the numbers would be lower as well. It's kind of an industry standard to rate consumer trucks & commercial trucks differently.
          Old Jun 15, 2017 | 10:48 PM
          seventyseven250's Avatar
          seventyseven250
          I feel like 400 ft-lbs would be enough for pulling my trailer around, so it seems like I have lots of options! That's great, now I just need the money to buy one.
          Old Jun 15, 2017 | 11:06 PM
          CuNmUdF250's Avatar
          CuNmUdF250
          They suppress the 5.0, it could easily exceed 400hp... the ecoboost is their thing now.
          Old Jun 15, 2017 | 11:11 PM
          Bullitt390's Avatar
          Bullitt390
          Certified Thread Hijacker
          I agree, Ford is sandbagging the 5.0, not only in HP/TQ but also MPG
          Josh
          Old Jun 16, 2017 | 05:11 AM
          NASSTY's Avatar
          NASSTY
          Everybody always wants more, but 395 HP /400 ft.lb. is pretty impressive for a small displacement V8. The Chevy 5.3 only makes 355 HP / 383 ft.lb..
          Old Jun 16, 2017 | 07:14 AM
          heymrdj's Avatar
          heymrdj
          Josh
          The 5.0L is the powerhouse fleet engine (vs the V6 which is used by fleets that need a truck bed, but not much power capacity). It's designed to be rugged, run hard, put away wet, and still make good power. You can't make a rugged engine if you're wringing every last ounce of power out. The F-250 6.2L is a great example of this. The fact that they have added direct injection and done upgrades shows they are committed to the platform, they are just not committing in the direction you want them to.
          Old Jun 16, 2017 | 07:00 PM
          CuNmUdF250's Avatar
          CuNmUdF250
          A few tweaks from factory and the 5.0 would obliterate the ecoboost engines ( let alone GM's offerings ), the ecoboost is/was supposed to be the future of powerful fuel efficient engines. Slight problem the 5.0 is as efficient if not more efficient.They don't want the 5.0 as the brands marquee engine.
          Old Jun 16, 2017 | 07:39 PM
          heymrdj's Avatar
          heymrdj
          What tweaks would make it as powerful as the ecoboost while running 87 octane and standing to miss a few oil changes, and be driven hard with a trailer on the back all day? Of course said engine would still need to be as fuel efficient as the eco as well, so you've got to factor that in too. Because that's what the 5.0's duty is.
          Old Jun 16, 2017 | 08:14 PM
          Terryd91's Avatar
          Terryd91
          And they could put the slightly modified raptor EB in the regular f150 but it won't happen. Your not going to get the low end torque out of the 5.0 with out forced induction, that is where the EB shines. Both are great engines and both have a different target audience.
          Old Jun 16, 2017 | 08:55 PM
          NASSTY's Avatar
          NASSTY
          In stock form there isn't a huge difference in power between the two. Aside from the Ecoboost makes more power on the low end and the 5.0 makes more on the top end. For equal $$....add an aftermarket tune to each and the Ecoboost will have a substantial advantage. If you have deep enough pockets to add forced induction to the 5.0 ($6k-$7k) than the 5.0 will be in a league of it's own.
          Old Jun 16, 2017 | 09:54 PM
          Tom's Avatar
          Tom
          Where do you get that from? Curious to know your source for so clairvoyantly determining their intentions. Why would they have anything against the engine that they designed and built? If they did...why in the heck would they even go through the hassle of designing and building it?
          Why would they go through the hassle with redesigning the heads for direct injection?
          Old Jun 16, 2017 | 10:08 PM
          CuNmUdF250's Avatar
          CuNmUdF250
          So you don't think ALL their advertising is geared towards the Ecoboost platform. Clearly Ford is pushing the Ecoboost. I have no direct line to FOMOCO but it's obvious they want the Ecoboost engines to outshine anything else they offer.
