Clifford's Big Red Build Thread
Old Oct 4, 2023 | 02:05 PM
  #331
thor363's Avatar
thor363
Originally Posted by EXSwap
Thanks! I might try out a set of 35s first and see what I think. I don't think I'll be disappointed in the overall look of the X and it might get me just enough for the little towing I do these days. And if it doesn't, I can go to a taller gear.
Thanks! I'm running 17" wheels these days. Interesting that you say "flubbery". One of the complaints I had driving with the trailer was that the rear of the X was a little wobbly. I attribute most of that to the hitch I was using. It's one of those multi piece hitches where you can move it up or down based on trailer height. If I were towing that trailer all the time, I'd get the appropriate drop height in a standard hitch. The other part though, seems to me to be the tires. I have them aired down a bit, but they are 10 ply (E range), so I could crank them up a bit next time (if there is one).
I have one of those adjustable height hitches also for when I'm just pulling a random trailer. My TT trailer weighed down is only shy of 8,000 lbs, but when I tow I run 60 up from and 65 rear. Centerline hitch (I know not the greatest, but with stronger bars than I need) and I'm pretty sure max inflation on my Nitto's is 80 lbs. Haven't needed that much pressure though. It's not the least bit wobbly or mushy.
Old Oct 4, 2023 | 02:29 PM
  #332
JAck19's Avatar
JAck19
Wouldn't anything beyond 4.30 be a bit low for a diesel?
I like the term “flubbery". Whenever I put on my mud tires, I kept them at 32, but every now and then they would slowly drift down and I would catch it around 20 psi, whenever it would suddenly feel "flubbery". After filling back up to 32 it was much more planted.
Old Oct 4, 2023 | 03:38 PM
  #333
Antonm23's Avatar
Antonm23
Depends. My old 2008 F350 diesel had 4.30's stock (part of the "tow boss" package if I remember correctly). Running a 37-inch tire on 4.88s would probably be higher gearing than stock size tires on 4.30s. But with the double overdrive G56 trans Keith is running, he can deal with some extra low gears.
Old Jul 4, 2024 | 11:16 AM
  #334
dazedandconfused's Avatar
dazedandconfused
Did you ever figure out the ac? I didn't know if I missed it or it wasn't discussed. I have an 01 Excursion with a 24v Cummins in it I'm finally getting around to hooking the AC up on and was wondering. You have a nice build and your pretty local to me I believe.
Old Jul 5, 2024 | 08:10 AM
  #335
EXSwap's Avatar
EXSwap
I did, but I haven't fixed it yet. The swaphelper box runs the tach, which requires the harmonic balancer to have the two "gaps" in it. When I looked at a 12V motor for the gap dimensions (because mine didn't have them from the factory, another story), I saw only one. So, I had one milled in, not two. Therefore, my tach reads about half of what it should. The X PCM (I think) wants to see at least 600 RPM in order to allow the AC compressor to run. So, mine doesn't. I haven't bothered to fix it yet as I prefer to drive with the windows down. When it's too hot for that, I just flip the switch to manually turn on the AC compressor.
That switch is just two wires running from the AC relay. I just connect the two terminals with the switch to make it work.
Any other specific questions I'm happy to answer. And yes, Walton KY is pretty close to Cincinnati. Good luck!
Old Jul 5, 2024 | 10:14 AM
  #336
Antonm23's Avatar
Antonm23
I’m running a swap helper tach helper and a harmonic damper meant for a 94-98 Dodge Cummins 12 valve on a swapped Excursion , the ac just works like normal (so does the tach).
Like Keith said above, the computer just needs to see the engine RPM above a certain number to allow the ac clutch to engage. Do you have the tach working yet?
Old Jul 8, 2024 | 11:59 AM
  #337
dazedandconfused
No I have not gotten the tach working yet but I will be shortly. Thanks for the information.
Old Jun 17, 2025 | 09:39 AM
  #338
EXSwap's Avatar
EXSwap
Well, haven't updated this in a while. The X has mostly been sitting after finding that my turbo is loose between the hot and cold side. Just haven't had time to mess with it. Unfortunately, we had a tree branch come down late Sunday night and the old boy is likely toast. I should find out today after the insurance company takes a look at it. Being that the roof is caved right on the corner, I suspect that they'll want to total it. If they do, I'll be on the search for a rust free version to put all my goodies back in.
Jeep also took the brunt. Hard top is smoked and the hood as well.
Unfortunate turn of events.
Old Jun 17, 2025 | 10:23 AM
  #339
thor363's Avatar
thor363
Darn sorry Keith! So much work went into that truck.
Let me know if you need eyes for another rust free one for the heart transplant. We should have a few rust free in the area.
Old Jun 17, 2025 | 10:31 AM
  #340
Antonm23's Avatar
Antonm23
That sucks,,,,but you could cut the roof off, build a roll cage and have a fun off road truck. Considering you have both a JK (sorry about that one too) and a lifted Excursion, I assume you're into off-road stuff.
Old Jun 17, 2025 | 10:45 AM
  #341
EXSwap's Avatar
EXSwap
Yeah, it's not fun. I will be in the market for a rust free version, but not likely for a while.
Old Jun 17, 2025 | 10:51 AM
  #342
EXSwap's Avatar
EXSwap
It's not fun at all. It is funny though, my buddy sent me this pic and said I should make lemonade out of my lemons.
The X isn't really offroad necessarily, but the Jeep definitely is. Hopefully I can get it sorted before our trip in July as we flat tow it behind the coach.
Old Jun 17, 2025 | 11:14 AM
  #343
Antonm23's Avatar
Antonm23
Yes... that, but in red, and maybe a little lighter weight because rust (that fortunately you already have) is lighter than carbon fiber.
Maybe grab you one of these (see link below)
https://www.affordablebender.com/
and a Sawzall (that I'm sure you already own) and you could be done in a weekend.
Old Jun 17, 2025 | 11:58 AM
  #344
WE3ZS's Avatar
WE3ZS
Wow Keith, sorry to see the damage to the EX, Jeep and tree. If this leads to a new project please be sure to bring all of us along for the ride!
Old Jun 17, 2025 | 05:05 PM
  #345
EXSwap's Avatar
EXSwap
Thanks Tom! For sure will be doing another project. Unsure what, but there's too many good parts in the X and just enjoy the crap out of driving it. Most likely another X if I can find one that's unmolested and more importantly RUST FREE.
SuperDuty93
30
Apr 30, 2022 09:17 AM
Diesel_Brad
Jan 29, 2017 06:20 PM
andym
Dec 3, 2014 08:06 PM
DIYMechanic
Oct 19, 2011 07:39 PM
X-70STANG-F150
May 2, 2008 06:02 PM
