Torque Pro OBDLink MX Chalenge
Old Jun 13, 2017 | 09:16 PM
Skydivelout's Avatar
Skydivelout
Hey guys when i select real time monitoring about 5-10 seconds later truck shuts down. I'm sure its me missing something, monitoring PIDs as per the sticky, all tested offline and say not connected to ECU when doing so. Any thoughts?
Old Jun 13, 2017 | 09:19 PM
AllaboutMPG's Avatar
AllaboutMPG
One of the formulas is not right. With key on engine off go through each pid and test. One or more of them will fail to test.
Old Jun 13, 2017 | 09:20 PM
AllaboutMPG
Did you manually load pids? IIRC the one that gave me trouble was throttle position but it's been a while
Old Jun 13, 2017 | 09:29 PM
Skydivelout
thanks man, I'll work through them, and yeah most are manual. Only tube fed is one transmission temp for comparison
Old Jun 13, 2017 | 09:43 PM
AllaboutMPG
Tugly has warned many times to test them before actually cranking the truck and trying them out. I thought I've got really good attention to detail I'll be very careful loading them. So I loaded a bunch, got in a hurry wanted to try them out. crank the truck then hit real time and it almost immediately backfired violently and shut down. I thought crap I hope I didn't mess something up. Went through and tested them and sure enough I had one or two that I had put the formula in wrong
Old Jun 13, 2017 | 09:55 PM
djed's Avatar
djed
In case it is relevant, mine works perfectly EXCEPT when I try to pull codes. I have a 2001 and Pop has a 2000 and we both have the same problem.
I am using a cheap OBD device.
I otherwise agree with with the above advice previously posted about trying things out first.
Old Jun 15, 2017 | 02:49 PM
Skydivelout
Just noticed my "TITLES' didn't match the guide as I was trying to 'unique' them when it came to selecting them from the menu so they would stand out. Totally my fault - reprogramming now lol
Ted928
1997 - 2003 F150
Jul 7, 2019 12:19 PM
FrankNBeans
Jan 25, 2017 02:56 PM
truckfella
Modular V10 (6.8l)
Dec 1, 2016 06:06 AM
lemonshindig
Apr 26, 2015 02:09 PM
mach8274
6.7L Power Stroke Diesel
32
Oct 25, 2011 08:11 PM
