My Torque pro app is showing "No Data" for EOT. All other PID's are working fine. Does anyone know the EOT PID? I will try and enter it manually if some can show the link to the EOD PID.
Thank you!
Thank you!
Did it work before? Maybe the senders gone out... Here you go:
PID 221310
Long Name: Engine Oil Temp
Short Name: EOT
Min.: 0.0
Max 300.0
Scale Factor: x1
Unit Type: (deg. symbol) C (not sure about this, I'm reading this not hooked to the truck)
Equation: (((A*256)+B)/100)-40
OBD Header: Auto
thank you! My truck was dead with a leaking STC fitting when I loaded all the PID's. Now that my truck is running I want to view my Delta's and noticed my EOT wasn't working. I will reload what you gave me and see if it will work.
Sorry, but we've had a network outage for a couple of days so just getting a chance to offer more... Here is something else you might be interested in - other gauges, including a calculated delta, that you can custom build:
