Engine and Trans ID
Old Jun 13, 2017 | 12:50 PM
ddepumpo's Avatar
ddepumpo
Engine and Trans ID
I know a little about Mopars and Corvettes, but am new to the Ford world (I like ‘em all). I recently purchased a 1974 F100 XLT short bed, and am trying to identify the engine and transmission. I’ve ordered the shop manuals which should help. I hope I don’t wear out my welcome, but I have a few questions.
The truck manufacture date is 07/74, VIN F10GUU84XXX. I believe the truck originally had a 302. It had a 6 cylinder when my seller acquired it, and he installed the current 351W.
351 W Engine ID questions: The block number is D1A1 6015 DA14, date stamp is 1D16 (as best determined with starter in the way). Is the date April 16, 1971 … or could it be 1981? What information does the block number tell? Is it possible to determine if this was a truck motor, or from a passenger car (if there is a difference)?
Flywheel question: If the engine seems to run smoothly, can I be confident that the seller used the correct balance flywheel (i.e. not the one from the 6 cylinder)? Would the 6 cylinder flywheel even fit the crank bolt pattern?
Transmission ID (3 speed manual): The date stamp appears to read 9A31. I assume 9 means the year, but is it 1969 or 1979? The transmission ID tag says RAB 3 and E0750 … what does that mean?
Thanks
Old Jun 13, 2017 | 11:05 PM
PapaBearYuma's Avatar
PapaBearYuma
Thanks
The letter D generally indicates decade of the 70s, but 71 seems pretty early for a 351w. But NumberDummy will likely be along shortly, to inform us with authority.
Old Jun 14, 2017 | 04:12 AM
KULTULZ's Avatar
KULTULZ
Post
The Engine Code (Original Install) is in the VIN.
-Casting Numbers and Date Codes-
Old Jun 14, 2017 | 08:27 PM
ddepumpo's Avatar
ddepumpo
Thanks for the info.
Old Jun 14, 2017 | 10:27 PM
nutinbutford's Avatar
nutinbutford
Welcome to the forum ddepumpo. The VIN number is for an F100, built in Louisville with a 302. If you're REALLY interested in knowing how the truck was originally configured you can order a MARTI report from Marti Auto Works. Hope this helps.
Old Jun 15, 2017 | 05:16 AM
KULTULZ's Avatar
KULTULZ
Post
D1 In The Engineering No. Indicates 1971 Model Year Release
Date Code 1D16-
1 = Year (1971 In This Instance)
D = Month (MAR)
16 = Day of Month
The 351W was released in the 1969 model year.
Old Jun 15, 2017 | 10:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by KULTULZ
D1 of the blocks casting number prefix D1AE (it's not D1A1) indicates 1971.
Date Code 1D16-
D = Month (APRIL). A = January, M = December, the letter I is skipped.
16 = Day of Month
Engine block cast April 16, 1971.
351W introduced in misc. 1969 Ford/Merc passenger cars, installed in: Econolines in 1975, Lincoln/Continental Mark VI in 1980, F150/350 & Bronco in 1981.
1969/77 F100 302 & 1975/77 F150 302 would have come with a C4 (11 trans pan bolt holes) originally.
1978 was the first year that the 302 was available with a C6 (17 trans pan bolt holes) in F100/150, but the C4 was also available.
Old Jun 15, 2017 | 03:26 PM
ddepumpo's Avatar
ddepumpo
Thanks to all who replied. This is very helpful. The dating system is starting to make sense to me.
Old Jun 15, 2017 | 03:58 PM
KULTULZ's Avatar
KULTULZ
Post
I always had trouble with the dating system. Not many girls would go out with me...
Glad it helped. Now you can understand what they mean by a numbers correct restoration.
FORD also uses this to help track-down defective parts.
Old Jun 15, 2017 | 04:06 PM
KULTULZ's Avatar
KULTULZ
Post
Could the prefix be D1AE?
DIAx 6015-DA I.D.'s as a 351W
Date Code interpret is correct. RAB 3 is the trans type and E0750 will get you into the correct parts list for that particular trans. Decade of the date code would have to be used with any trans component (say main case or tail-shaft housing casting marks) or of course the trans code will I.D the asm correctly in the Master Parts Catalog.
Old Jun 16, 2017 | 08:39 AM
ddepumpo's Avatar
ddepumpo
Hah, that was actually very funny about the dating system. I stepped right into that one. So, it looks like I need to find the decade letter for the trans date of 9A31. So I guess a 1971 351W should be a pretty stout motor. I will run a compression test today to get an idea of condition. Thanks again.
Old Jun 16, 2017 | 10:07 PM
ddepumpo's Avatar
ddepumpo
And I forgot to respond to Kultulz... upon further review, yes it is D1AE, not D1A1. Thanks.
Old Jun 17, 2017 | 02:50 AM
KULTULZ's Avatar
KULTULZ
Post
THANK YOU!
jeepnatv4life
1997 - 2003 F150
Mar 12, 2016 07:24 AM
balboni
Aug 18, 2015 05:09 PM
CharlieLed
Nov 9, 2014 10:34 PM
investedocean
Dec 18, 2008 10:22 AM
Dan76'F100
Jun 14, 2003 08:56 AM
