Periodic Transmission Leak
01 F-150 7700 ed.
I have a 4R100 Tranny with a 139K miles. It has been rebuilt. Ever since the rebuild (over 10 yrs ago), if I park the truck for a week or so or more, I will end up with a decent size puddle of trans fluid underneath the truck. I took it back to the shop that did the rebuild a couple times, but they could never find anything. It leaks enough to where my fluid level drops enough to cause the transmission to slip in a U-turn because the pickup tube becomes uncovered. I have a couple theories, but am wanting to hear from the collective.
Theory #1 When I park it on my slightly sloped driveway I don't regularly use the parking brake, so it rests on the gears, which eventually forces fluid out an overflow or breather tube.
Theory #2 (a very thin one) due to pressure changes associated with the weather, fluid is somehow siphoned out a breather tube due to some blockage internally in the tranny to where it's not equalizing with the outside air and has a high pressure within... ( i kinda laugh at myself for this one, but I am at a loss over the source of this)
I have nothing else... Any ideas? Thanks in advance.
Thanks for the replies.
I did go staring up there a few times post puddle, and it appeared to be coming from the top near the mating flange if I recall correctly, which is why I left off because I couldn't see well up there, but I'll use a better inspection mirror or camera this time. I will go inspect some more and see where I end up. Thanks again.
So I came home this morning and lo and behold I had a nice puddle (it's been sitting for a week or just over). I only had time today to snap these 2 pictures before I hit the road again for work. I'm going to have to jack the truck to get under there properly to get a better look, but you can see some of the extent of the issue.
Had a Dodge 2500 that the dipstick "O" ring failed. The dipstick just pushed into a portion of the transmission case and into the pan. It was a snug fit, and when the O ring failed, the fluid came out.
It was the same situation you describe, park it for a few days, and I had a nice puddle underneath it. And as Mr. Kovalsky mentions, the drainback valve leaking back, would cause the level to rise, and if the trans dipstick O ring is brittle, you get a puddle. Jsut something to check, the O ring is a cheap easy fix. The drainback valve is sounds like a major deal to pull the transmission.
PSNut
08-19-2007 06:35 AM
286merc
10-22-2005 09:44 PM
