HELP - HellWig Fit Problem
Old Jun 10, 2017 | 05:06 PM
bushpilot's Avatar
bushpilot
I am '17 F350, SRW, LONG BED 4x4
The bar is the Hellwig 7294 (adjustable)
It would appear that the Frame Mount holes are either too big or the Bolts & Dogbone / End Link are too small.
I don't know how I could hold the nut in place to get the bolt tightened.
Any one done this on the long bed? did you have issues w/ the holding the nut in place (there is not access from the other side of the frame.
In this picture I double check to see where the the end-link will attach...confirming that I'm using the correct frame mount/hole
In this picture I'm TRYING to hold the nut in place (even w/ a washer the fit is wrong)...but you can see 1) there is no access to hold/tighten the nut and 2) the nut is WAY too small & would likely pull thru (even w/ a washer).
Again this picture compares the Frame Hole and the bolt...WAY too small / Sloppy...
Hints and Assistance would be appreciated...
Old Jun 10, 2017 | 05:58 PM
bushpilot's Avatar
bushpilot
the box says dually but their website says Pickup and Dually.
I suspect they've forgot this bracket and hardware in their kit....
Old Jun 10, 2017 | 07:22 PM
maabx's Avatar
maabx
This is the Hellwig Bracket...
Old Jun 10, 2017 | 08:23 PM
bushpilot's Avatar
bushpilot
Attachment 186524
*******S !!!
Old Jun 11, 2017 | 08:33 AM
maabx's Avatar
maabx
Looks like your kit is for the dual rear wheels only. I have the Hellwig 7320...
Sway Bars For Trucks, Suvs, Vans, And Motorhomes for the 2017 Ford F-350 Super Duty | TruckSpring
Old Jun 11, 2017 | 08:44 AM
bushpilot's Avatar
bushpilot
7320 ?? thats not even listed as an available part for the 2017
Old Jun 11, 2017 | 08:51 AM
bushpilot's Avatar
bushpilot
at the end of the day, the bigwig bars for the 2017 are all the same providing options for adjustability, and bar thickness...the difference between he DRW & SRW is the frame adapter/bracket.
i now know the frame brackets were left out of this kit - for one reason or another - I'm confident that HellWig will resolve the problem quickly.
Old Jun 11, 2017 | 08:54 AM
maabx's Avatar
maabx
Read the following. Looks like their website is not up to date...
Hellwig Releases Sway Bars For 2017 Ford Super Duty Trucks
Old Jun 11, 2017 | 09:01 AM
bushpilot's Avatar
bushpilot
thanks!
apparently their dealer/reseller network isn't up to date either.
ill be sure to call this to their attn when i talk w/ them tomorrow....
Old Jun 11, 2017 | 10:45 PM
workingdan's Avatar
workingdan
I didnt get the frame brackets either. I had a hell of a time putting mine in the frame. Ill have to call and get the brackets.
Old Jun 12, 2017 | 09:51 AM
bushpilot's Avatar
bushpilot
Nice guys at Hellwig....they understand the problem and are sending the necessary (additional) hardware.
I also made them aware that the 7320 bar is NOT listed as an option for the 2017 super duty on their website.
problem solved, minor hassle.
Old Jun 12, 2017 | 10:40 AM
DL222's Avatar
DL222
I ordered a 7320 from summit racing was told it's on back order. Supposed to ship out from Hellwig the week of the 19th.
Old Jun 17, 2017 | 10:53 AM
DL222's Avatar
DL222
Got the Hellwig Big Wig 7320 installed.
Old Jun 17, 2017 | 06:54 PM
wb6anp's Avatar
wb6anp
Any suggestion, I don't tow or carry heavy would the regular hellwig anti sway be better? or stick with the big wig.
Old Jun 17, 2017 | 07:15 PM
bushpilot's Avatar
bushpilot
stick w/ the bigwig bar - its adjustable.
jshalala
Jul 24, 2013 09:18 AM
Aaron-71
Aug 30, 2011 06:10 PM
SCD
Jun 24, 2011 05:45 PM
milesg
Aug 31, 2006 04:03 PM
1low50
Jul 16, 2004 10:40 PM
