Boxing the Frame
Old Jun 23, 2011 | 02:06 PM
SCD's Avatar
SCD
Boxing the Frame
I am in the middle of installing boxing plates on the rear of my frame. I am trying to determine if I need to provide access holes through the boxing plate to attach the bed later. On the two center bed cross sills and the front bed cross sill do I need to provide an access hole to get to the nut that bolts the bed sills to the frame or can I simply weld the nut to the inside of the frame before I install the boxing plate. If I can weld the nut in, what size and thread pitch should I use?
Thanks in advance!
Scott
Old Jun 23, 2011 | 06:14 PM
rhopper's Avatar
rhopper
I'd make some access holes. Make sure you make the holes big enough to fish the nut inside AND get a wrench on it. Experience talking here. Don't forget to allow for running boards attaching to the frame. Holes or nuts for that, too.
Old Jun 24, 2011 | 05:45 PM
SCD's Avatar
SCD
Rhopper
I welded nuts in place for the running board brackets as well as the brake peddle assembly and front and rear cab mounts. I was hoping that I could do the same for the bed cross sills. I think that would be cleaner than an access hole.
Thanks for the input.
Scott
krisg
Vehicles for Sale
Oct 24, 2016 07:41 PM
norcalfox
Sep 9, 2014 09:05 PM
ericboj
May 25, 2014 08:29 PM
BigBlueIron
May 13, 2013 05:24 PM
tip49
Aug 29, 2008 11:03 PM
