4.9L Timing Gear Fail???
Old Jun 7, 2017 | 11:12 AM
seagiant's Avatar
seagiant
Hi,
I was running down the Interstate yesterday on a trip and my engine just stopped...DEAD, no power!
Had the tow truck stop at a shop and had the mechanic scan the engine (I was thinking the computer shot?)
They said they thought the timing gears were shot?
It is now going to a real Mechanic, but are the straight 6 engines known for this???
Engine has only 85,000 miles on it?
What are my chances no bent valves or rods?
Didn't hear any knock when it quit....fingers crossed!
Old Jun 7, 2017 | 11:26 AM
Middleagecrisis's Avatar
Middleagecrisis
The 300 six cylinder is gear to gear, no chain, so I would be surprised if that was your problem. Does it backfire when you tried to restart, or just spin? Just spinning over would indicate an electrical issue.
Old Jun 7, 2017 | 12:12 PM
animator's Avatar
animator
It's entirely possible for the gears to fail. They are phenolic, so breaking one is not impossible or unheard of.
Old Jun 7, 2017 | 01:01 PM
'89F2urd's Avatar
'89F2urd
It's very common for the 300 cam gear to chunk teeth, it's a nylon gear.
Take your distributor cap off and watch the rotor while cranking. If it doesn't spin, check dizzy gear...if dizzy gear is in tact, it's your cam gear.
Replace crank and cam with steel gears and you won't have to worry about it.
Old Jun 7, 2017 | 02:41 PM
seagiant's Avatar
seagiant
Hi,
Thanks!
Mechanic is taking the front off this evening!
He also thinks it is the "plastic" gear!
Hope that is all it is, will know more tomorrow!
Old Jun 7, 2017 | 03:35 PM
'89F2urd's Avatar
'89F2urd
Well, no sense in taking it apart if the distributor spins.
Old Jun 7, 2017 | 05:55 PM
seagiant's Avatar
seagiant
Hi,
Distributor does not spin!
I think it is in good hands!
Thanks!
Old Jun 7, 2017 | 07:20 PM
Eddiec1564's Avatar
Eddiec1564
MAKE SURE they clean out the oil pan from the plastic cam gear parts! That will plug up the oil pickup screen and cause major problems!
Old Jun 8, 2017 | 05:06 AM
seagiant's Avatar
seagiant
Hi,
Thanks!
I'll look in to it!
Old Oct 5, 2021 | 05:59 PM
Robmellow62's Avatar
Robmellow62
Originally Posted by seagiant
Hi,
Thanks!
I'll look in to it!
please do ! I went down this road twice as the Ford Dealership that repaired my engine the first time did not and I ended up with a trashed motor and buying a junkyard engine ( that shat its timing gears 6 most. Later )
zaktpl
Jul 24, 2019 08:43 AM
spear1up
Oct 22, 2013 01:33 PM
Roy C
Jun 20, 2011 04:57 PM
AC-MAN
Nov 20, 2008 09:02 PM
jerrycarl
Jul 6, 2004 12:55 AM
