timing gear
Old Jun 18, 2011 | 12:10 PM
Roy C's Avatar
Roy C
timing gear
I just got my '87 4.9L back from the shop. The guy didn't do hardly anything other than the head work and also bought parts. He bought a cam shaft for it that has a fiber timing gear. I'm not exactly sure what the gear is made of but it's not metal. Has anyone out there had any experience with something like this before?
Old Jun 18, 2011 | 02:20 PM
fordinlinesix's Avatar
fordinlinesix
Yes, tons of them have fiber gears, usually you don't get any problems out of them.
Old Jun 18, 2011 | 02:59 PM
Roy C's Avatar
Roy C
Do both of the gears have to be fiber OR can the crank gear be metal?
Old Jun 18, 2011 | 04:20 PM
F-250 restorer's Avatar
F-250 restorer
IIRC ford went to the fiber cam gear in 84. If you are adding any mods to your engine like an aftermarket cam, stronger than oem v.springs, higher compression, then you should use an all metal set of t.gears. It you are staying oem, then all is good.
Old Jun 19, 2011 | 10:55 AM
AbandonedBronco's Avatar
AbandonedBronco
I believe only the cam gear was phenolic (plastic) and the crank was always metal. It's a big noise reduction. You really only need the full metal/metal gears if you plan on beefing up the engine.
Old Jun 19, 2011 | 05:31 PM
fordinlinesix
Yup, only the cam gear is fiber
Old Jun 20, 2011 | 04:57 PM
seattle smitty's Avatar
seattle smitty
My '66 Econoline 240 went well over 100,000 miles before shredding the teeth on the phenolic cam gear. The usual advice is to replace it with a metal gear. I would do that for sure, if I had a cam with more lift than stock, or higher ratio lifters, or just worked the engine harder. None of that applied to my old 240, and a friend had a new fiber gear, so I used it.
