p1211 driving me crazy!
Old 06-05-2017, 12:57 PM
Keith Poole's Avatar
Keith Poole
Keith Poole is offline
- Just did the hutch mod and added a suction side Baldwin fuel filter, don't remember part#
- did all hpop and fuel bowl seals, hpop gasket
- New motorcraft icp and ipr
- Max hpop under load is around 2700 psi, 600 at idle.
- Fuel pressure steady 55 psi at idle, drops to 45 at wot
-no noticeable driveability issue... Just a bit sluggish but maybe that's just because it's stock- no tunes
-symptom seems to be ipr goes to 65% consistently whenever I hit the gas a little too hard or going up a grade on highway. Pressure seems to be good but ipr% slightly high when driving. Around 10-11% at idle.
Is this a sign of weak hpop? Truck has 150k.
Old 10-07-2017, 02:48 AM
2000 7.3psdEx's Avatar
2000 7.3psdEx
2000 7.3psdEx is offline
Have you checked the wiring to the icp and ipr? There's a possibility its the hpop. Most stock trucks I've seen idle at 7.8-9% at idle.
Old 10-07-2017, 08:18 AM
Tugly's Avatar
Tugly
Tugly is offline
1. Either that Baldwin pre-filter is a little too restrictive, or you're still getting air in the fuel. Your fuel PSI should not dip that low with stock injectors.
2. You might just have tired O-rings on your injectors. You can look up "Cody test" to find out if this is the case.
Old 10-08-2017, 12:07 AM
The Brad's Avatar
The Brad
The Brad is offline
Are you running any tuning, chip or programmer? Are you able to monitor injection pulse width? No doubt you introduced air into the HPO system while working on it. How many miles since the repairs?
Old 10-08-2017, 12:30 PM
andym's Avatar
andym
andym is offline
My fuel pressure is at ~64 psi while idling, and drops to the mid fifties under heavy throttle. I am running and FRx with the gold spring and I didn't put the fuel pressure gauge in until after it was installed so I don't know what the stock fuel system is supposed to run at.
I also run a baldwin pre-pump filter (BF1212) if that helps any.
Old 10-08-2017, 08:03 PM
F350-6's Avatar
F350-6
F350-6 is offline
This first.
Old 09-24-2018, 08:18 PM
Keith Poole
no tunes, no chip, no programming, it's all stock. i have torque pro and the elm327 bluetooth adapter but i don't believe i'm able to use this to monitor injector pulse width. the mileage is at around 160k and still having the same p1211 issue. i finally got the courage to put my gopro in the valley to try and find leaks, and found this...
i've pulled all 8 injectors twice to fix leaking/cracked cups. the first time after installing i failed to pressure test the cooling system and didnt glue them in the right way. i replaced all the injector o-rings, hopefully i didn't damage them on reinstall..
i've had the hpop out before to do all the seals and new servicable plug/new ipr, replaced the hpop gasket and the lower hpop reservoir to front cover gasket (with the screen filter). the video looks to me like it's leaking from the hpop gasket. only thing i can think would cause this is if there was some dirt on the surface when i put the gasket on. i'll pull it again and put another gasket on to see.. could this also be due to something on the hpop itself? or maybe front cover cracked/warped? i hope this leak is the source of p1211 code
Old 09-25-2018, 05:37 PM
F350-6's Avatar
F350-6
F350-6 is offline
It's possible you have a crack in the HPOP housing that is leaking, but like you, gasket would be my first suspect. Of course you'll need to pull it either way to see.
The front cover being a powdered metal, I don't think it can warp, but if something odd happened, then some RTV carefully applied would take care of that.
Old 09-25-2018, 06:36 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
OT...i cant remember but, the hpop is only held by the 95# torque needed, bolt..right? I "fixed" a plug on mine and she seeping again.
Old 09-25-2018, 06:51 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Negative, the drive gear is held on with that nut to that torque, the pump is held on with two or three or four bolts that are on the other side of the pump.
Old 09-25-2018, 07:05 PM
timmyboy76's Avatar
timmyboy76
only accessible with fuelbowl removed? Wonder if mine are loose...
Old 09-25-2018, 07:20 PM
Walleye Hunter
I don't know about that one.
Old 09-30-2018, 10:52 AM
Keith Poole
I took it all apart and found a tear in the gasket. Tried to reinstall with a new gasket and torque the mounting bolts to 18 ft/lb but only could get it to 15, then the bolt ripped out the threads.
So now I'll be drilling out the driver side hole in the front cover and installing e-z lok steel inserts. Hopefully this will make it stronger... Those aluminum threads have to withstand the 3000+ psi the hpop makes, probably explaining why this is such a common issue.
Do I just drill out the stripped hole, or should I go ahead and do both?
Damaged gasket
Old 09-30-2018, 12:13 PM
timmyboy76's Avatar
timmyboy76
I just lost my breakfast, keith.. damn! Bright side, the hole looks already for threads to be made.. I gotta leak. Im starting with ipr. Had the hpop out once. That was enough
Old 09-30-2018, 03:58 PM
HD Rider's Avatar
HD Rider
HD Rider is offline
Just repair the bad hole. Drilling out the other one is asking for trouble.
2006powerstroke90
04-22-2017 05:45 PM
250 STROKER
20
04-09-2015 10:06 AM
fordman67
30
11-16-2013 09:34 PM
sdcowman
6.4L Power Stroke Diesel
02-07-2012 10:07 PM
Jaaaaaaackman
05-31-2006 07:47 AM
Quick Reply: p1211 driving me crazy!
