Install cruise control?
Old Jun 4, 2017 | 09:25 PM
Reddog84's Avatar
Reddog84
I have a 2015 BASIC f-250 6.7 diesel, and by basic I mean no carpet, crank windows and no cruise control. A GREAT truck that was purchased to pull our 10k lb travel trailer. Here is the problem, I NEED TO INSTALL CRUISE CONTROL!! So my question, to y'all experts is; what equipment EXACTLY do I need to install to the truck?? I have read things from nothing more than just adding the controller to the steering wheel and flash the computer, all the way to take off the transmission to install a servo to the throttle cable. I would assume the truck would need some sort of servo/control lever installed, but then I wonder if the speed control is done internal to the computer. I need help, thanks for your time!!!!
Old Jun 4, 2017 | 10:07 PM
Jeremy05's Avatar
Jeremy05
Not positive on the 2015....but on 2011 and 2012 which should be the same.
1. Its the switch in the wheel, just swap the old one out.
2. And using ids to turn cruise control on in programmable parameters, speed items, cruise control.
Old Jun 5, 2017 | 04:41 AM
Just Strokin's Avatar
Just Strokin
No servo needed on diesel. It is all "fly-by-wire" controls from the PCM/ECU.
Old Jun 5, 2017 | 06:05 AM
Reddog84's Avatar
Reddog84
Thanks for the quick reply y'all... Now, will/is this the proper part? http://m.ebay.com/itm/11-thru-16-Super-Duty-F250-F350-F450-F550-OEM-Genuine-Ford-Cruise-Control-Kit-/181196631754?fits=Model%3AF-250+Super+Duty&hash=item2a30292eca%3Ag%3ASwsAAOxy1 NxSC9Px&_trkparms=pageci%253A6dc19d60-49db-11e7-8581-74dbd1801d5e%257Cparentrq%253A77d7b62b15c0a861a5e4 2f44fffc982d%257Ciid%253A2
then once I purchase the part, will my dealer know how to flash the computer? One would hope right?!? Thanks again!!
Old Jun 5, 2017 | 06:57 AM
Just Strokin
That is the correct switch (Motorcraft SW-6769) if you have the basic instrument cluster without the center display. It is not the correct switch if your current switch has left and right arrows on it. There are cheaper prices for the switch you have in your link with free shipping.
MOTORCRAFT SW-6769 in eBay Motors | eBay
Old Jun 5, 2017 | 11:34 AM
Jeremy05's Avatar
Jeremy05
Originally Posted by Reddog84
Thanks for the quick reply y'all... Now, will/is this the proper part? 11 thru 16 Super Duty F250 F350 F450 F550 OEM Genuine Ford Cruise Control Kit
They should, if not follow my items listed on #2. You might as well have them turn on the % dpf full screen while they are there. Programmable parameters, personality, OCR "operator commanded regen" It takes 5 min tops per change. So 10min total for both changes in the computer, they'll probably try to charge you for 30min-1hr though.
Old Jun 5, 2017 | 02:04 PM
Just Strokin
You can get a USB ELM327 adapter and use FORScan to turn on the cruise paramters along with the Exhaust Screen and if desired, DRL's.
Old Jun 10, 2017 | 02:05 PM
Reddog84's Avatar
Reddog84
Dog full screen??
appreciate the information, but what does turning on "% DPF full screen" get me? What will that cause the truck to do/not do?
thanks again.
AmtrakDriver
6.4L Power Stroke Diesel
Feb 13, 2011 06:11 PM
cghstrojan08
1997 - 2003 F150
Mar 2, 2009 06:59 AM
Bolt
Dec 12, 2005 06:58 PM
