Sponsored by: Auxito
Cruise Control Question
Old Feb 28, 2009 | 07:29 PM
cghstrojan08's Avatar
cghstrojan08
Does a 1997-2003 F150 come prewired for cruise sontrol? I am looking at buying one but want to add factory cruise to it. Thanks guys.
Old Feb 28, 2009 | 08:49 PM
coatit's Avatar
coatit
most likely is but then you'd have to change out the steering wheel. might be easier to find one like you want
Old Feb 28, 2009 | 08:58 PM
cghstrojan08
Ok, thanks. It is no problem for me to change that out. What should I look for to tell if it is prewired or not?
Old Mar 1, 2009 | 08:14 AM
Ron1999's Avatar
Ron1999
I'm a little confused by the question.
Cruise control has been around for a few decades now. Seems to me that the model years you inquired about would already have cruise control installed.
If for some reason those model years don't have cruise control installed then it won't just be a matter of changing out the steering wheel. You'll have to install a cruise control servo, make sure the cruise control servo linkage will properly connect to the throttle linkage, install the cruise safety shutoff switches, etc.
Old Mar 1, 2009 | 09:08 AM
coatit's Avatar
coatit
Yes thats kinda what I thought, but the cruise would come w/ the servo,linkage,saftey switch,maybe even the new fuse link. The on off switches are in the steering wheel with the airbag.
I would think you would have to look pretty hard to find a truck withOUT cruise
Old Mar 1, 2009 | 09:21 AM
Ron1999's Avatar
Ron1999
That's correct. If the Poster did buy a cruise control system then it should have everything he needs in order for it to work properly.
But, he asked if those model years came "pre-wired" for cruise. That's what confused me. I couldn't see Ford installing all the cruise control hardware and then not install the proper steering wheel, or some other means of activating the cruise.
I have no idea what a cruise control system would cost.
Your suggestion to find a truck that already has it installed is the best answer to his question.
Old Mar 1, 2009 | 10:22 AM
cghstrojan08
Well, I have been looking at some V6 equiped trucks and most of them have not had cruise on them. I was just wondering if the plugs were there to hook up the cruise servo and stuff. I know on Rangers some did not come with cruise but some were pre-wired for it while others were not.
Old Mar 1, 2009 | 04:40 PM
Thomas Hutchins's Avatar
Thomas Hutchins
CC Retrofit
I would think that to be really effective, the Computer Chip and control module may well have to be changed out as well as the engine linkages.
I would look very close for any pit-falls, GOT-YA's and the like prior to purchasing a unit without a CC and then trying to retrofit one.
Old Mar 1, 2009 | 07:36 PM
ncranchero's Avatar
ncranchero
I can't answer if the F150 is pre-wired or not but I do know the Crown Vic's are ALL wired for cruise, installed or not. I'm going to add cruise to our Interceptor demo car next week. All that is required is a servo/cable assy and a steering wheel with cruise. Done several of them already. Wiring them all keeps Ford from having to make two different harnesses. So it IS done, for sure.
Old Mar 2, 2009 | 06:45 AM
Ron1999's Avatar
Ron1999
That's news to me. I dont' know why Ford, or any manufacturer, would do that.
"Pre-wiring" a cruise control system takes alot of parts. Especially considering all the built in safety cutoff switches. So, why would they leave out one, or two, parts?
Why not just install them and be done with it?
It can't be the money. This is all done on the assembly line. Just grab the right part and install it.
Unbelievable.
Old Mar 2, 2009 | 06:59 AM
ncranchero's Avatar
ncranchero
I guess since all of the sensors for cruise also feed info to the PCM for other functions it's just a matter of adding a few wires and connectors. Still, I don't know if they do that on the trucks.
dylansf23
20
Apr 23, 2025 02:57 PM
militarymonark
Feb 20, 2012 09:39 AM
79str8six
Feb 4, 2012 01:02 PM
johnson2007
Oct 20, 2010 01:12 PM
