E4OD Stuck In 4th Gear?
My 1993 Ford Bronco XLT with the 5.8 351w, E4OD, has been running fine just a little high and wonky idle, but it came back!. I can put my transmission in park fine, reverse fine, neutral fine, and low 2 and 1 fine, but overdrive seems really f**ked up!!! It will idle and coast fine in overdrive, but when applying gas it feels like its slipping bad, it takes around 20 seconds to get to 30mph, It's not actually slipping because of 1st and 2nd work fine, in fact, they engage a little hard! I'm getting a memory code: 654- Transmission lever not in park. Mabey MLPS THIS HAS BEEN DRIVING ME CRAZY FOR 2 YEARS!!!!!!
Please help me figure this problem out I don't have money to bring it to a professional.
The E4OD will stay in fourth gear when the shift lever is in OD if there is no power to the solenoids. The MLPS cannot cause this. Find out why the two red wires to the trans connector don't have power.
hey sorry i havent been on in a bit, the truck drove fine for a bit and then the problem came back
Ok so checked the 2 pins they have power, the problem is random. It wont go in drive and shifting to reverse make the truck jerk really bad. And then some times it shifts smoothly and has power in drive, can it be tps?
No, the TPS can't cause that. When it has the problem check those two pins for power. If they don't have power the trans will only have reverse and fourth, and will operate at max pressure all the time.
654 334 452 542 543 634
Did you forget from that post to this post?
Did you have it in park when you ran the test? If so, the MLPS is bad. If you didn't, that set the 654 and possibly the 634 code.
452 is vehicle speed. That may have some bearing on this problem. The other codes do not.
I still think your best bet is to check the two power feeds on the transmission harness when the problem is occurring.
Iron Port
1978 - 1996 Big Bronco
20
Mar 24, 2025 08:37 PM
