High Voltages
Old Jun 1, 2017 | 09:39 PM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by dnkensinger
I will test the voltage with the engine off/key on, but I had only tested coil voltage with the engine running so far, and it is slightly above 10 volts. I'm just not used to seeing that high of a voltage at the coil.
Good. Then we will know.
There probably isn't a meter made that can properly read that signal on AC, and certainly none on DC. But, when you turn the key on the ignition module goes low and current is conducted through the coil. So if a resistor is in the wiring the voltage at the coil will be less than battery voltage, and usually about 7 volts.
Old Jun 1, 2017 | 10:36 PM
Tedster9's Avatar
Tedster9
Gary, you have an ignition scope? *drools*
Old Jun 2, 2017 | 06:51 AM
Gary Lewis's Avatar
Gary Lewis
Yes, I have an ignition scope as well as a couple of regular bench scopes. That pic was from the solid-state bench scope, which has a better display and goes to lower voltage.
TobaccoBarn460
Sep 30, 2016 02:41 PM
xaviar
May 8, 2015 07:01 PM
dobeydude
Jan 29, 2013 08:22 PM
2001SuperCrew4x4
1997 - 2003 F150
Aug 3, 2011 12:58 PM
thuggishruggish3000
Jan 12, 2004 01:56 PM
