Fox 2.0 Rear Shock Availability Update
Old May 31, 2017 | 11:52 AM
snelldawg's Avatar
snelldawg
This might have been mentioned in another thread but I'm not sure.
I chatted with Fox today. They have no plans to produce a new shock for the 17's. They said that new rear bushings for the 17's will be provided with the 2016 model shocks in the box when purchased, in a few months.
Old May 31, 2017 | 01:34 PM
wfedwar's Avatar
wfedwar
Thanks for the update. I'm sorry to be ignorant on this, but do the new bushings slide in or are they pressed in?
Old May 31, 2017 | 01:45 PM
wb6anp's Avatar
wb6anp
You can just press the in with you hand or a mallet. I bought Bds fox 2.0 they came witth the proper bushings already. Only difference is the BDS sticker.
Old May 31, 2017 | 07:56 PM
Xwild's Avatar
Xwild
How do you like the BDS so far wb6anp? they have their own valving setup I believe compared to a stock Fox 2.0?
Old May 31, 2017 | 09:02 PM
das_16's Avatar
das_16
bds shocks are fox shocks they just put a bds sticker as well on the shocks.
Old May 31, 2017 | 09:10 PM
wb6anp's Avatar
wb6anp
The ride is much better than stock, stays planted much better, which isnt saying much as I had a blown oem shock.
Old May 31, 2017 | 10:03 PM
Litre's Avatar
Litre
I had no issues with mine. All 4 came with the Carli 2.5" level
Old May 31, 2017 | 11:59 PM
Tricon's Avatar
Tricon
I put the 2016 versions on the rear, got the resi with compression adjusters for towing. Night and day difference 👍 needed the updated bushings and sleeves. You can find part numbers in the Fox thread.
Old Jun 1, 2017 | 06:26 AM
System's Avatar
System
Prolocutor
Thanks for the info Snelldawg. That's different than what they were saying a couple months back. They must have decided it wasn't worth it to have a whole new part number when the change was so minor. So, the question is, have you ordered??
As to the BDS, they are not the same as the standard FOX 2.0. BDS buys their fox components in bulk and assembles their own shocks. They valve their 2.0 shocks differently than FOX does during assembly. I'm not saying that's good or bad. Just noting that it is different.
Old Jun 1, 2017 | 07:36 AM
System's Avatar
System
Prolocutor
PS: If anyone needs the rear bushings, I have a spare set for sale cheap. No sleeves, just the bushings. Drop me a PM if your interested.
Old Jun 1, 2017 | 09:54 AM
F250Smitty's Avatar
F250Smitty
This may be a question suitable for the other thread, but, If I order the shocks for my 17, as the part numbers are listed in the other thread, and I plan on installing a level kit someday in the future, will I need a different front shock? Sorry if this is an ignorant question!
Thanks
Old Jun 1, 2017 | 10:19 AM
System's Avatar
System
Prolocutor
Depends on how much level you are getting. The base part number is for 0-2" lift. Here are the front part numbers for more lift:
Model Year Position Lift Part Number
Ford F250 - Superduty 4WD 2016-2011 Front 0-1.5" 980-24-677
Ford F250 - Superduty 4WD 2016-2011 Front 2-3.5" 980-24-646
Ford F250 - Superduty 4WD 2016-2011 Front 4-5" 985-24-061
Ford F250 - Superduty 4WD 2016-2011 Front 5.5-7" 980-24-652
Rear:
Ford F250 - Superduty 4WD 2016-2011 Rear 0-1" 980-24-647
Ford F250 - Superduty 4WD 2016-2011 Rear 1.5-3.5" 980-24-653
Ford F250 - Superduty 4WD 2016-2011 Rear 4-6" 980-24-665
Old Jun 1, 2017 | 02:36 PM
F250Smitty's Avatar
F250Smitty
Thank you!
workingdan
May 15, 2018 11:33 AM
Jethro09
Sep 12, 2017 05:43 PM
Diesel and Steam
Oct 31, 2010 07:11 PM
Mitchcj
Aug 15, 2010 09:29 AM
blueeyes2478
Mar 9, 2006 05:47 PM
