turbo replacement
Old Jun 2, 2017 | 07:11 PM
  #31
SkySkiJason's Avatar
SkySkiJason
Originally Posted by Eaglescout94
It's reall simple, thought it was more involved than it really is. Get a 3" pvc pipe cap and drill a hole for a schrader valve. Remove the air filter on your truck and clamp the cap in. Air it with LOW pressure (15-20lbs) and listen for leaks.
I also took a look at the wheel in th turbo. It looks just fine but I wasn't able to check for any play. It's gonna be a bear to get the hose off to even reach it so maybe I'll try that tonight
Use a male air hose fitiing and then you just click it on and go hands-free looking and listening for leaks. Just turn press regulator down to 15-20 psi at your compressor. Costs less than s Starbucks!
FTE member Trey Spooner has a great YouTube video for a little more complicated version and how to use it.
Old Jun 3, 2017 | 10:49 PM
  #32
PASSIONATE_GRANDPA's Avatar
PASSIONATE_GRANDPA
OK thank you.
Old Jun 7, 2017 | 10:28 PM
  #33
Eaglescout94's Avatar
Eaglescout94
I've got a new KC turbo on the way so what should I get ordered to allow me to install it without a hitch? I'd imagine it would be a good idea to get rid of the ebpv but don't know for sure or what my options really are with it so what say you guys?
Old Jun 8, 2017 | 12:24 PM
  #34
SkySkiJason
Bellowed up-pipes if you don't already have them, plenum inserts, boots and t-bolt clamps for plenums/spider and AIH delete plug from Riffraff, pedestal orings... I don't hate EBPV, especially in cold climates. DIY delete for $0.25 or rebuild it for about $60.
Old Jun 8, 2017 | 12:40 PM
  #35
akcooper9's Avatar
akcooper9
Bellowed up-pipes
Which ones are you buying and installing for yourself/customers?
Old Jun 8, 2017 | 01:06 PM
  #36
Eaglescout94
I live in central Illinois so we can see some temps close to 0 or atleast did this past winter. Would it be wise to replace the up pipes even if mine aren't leaking? I don't think the ones on it now are very old. When you talk about DIY delete which part are you referring to? I've redone some reading so a little clarification would be nice.
Old Jun 8, 2017 | 06:25 PM
  #37
SkySkiJason
I've been using Dorman up-pipes and ceramic coating them. I've put on at least a dozen in the last 3-4 years and had no problems yet. That was not always the case... Prior to the current 'version' from dorman - this part was JUNK. They have revised it and the castings now look as good as Int'l but don't have the dead-end hole (that used to be too short). The only difference is Int'l uses 'stainless' tubing.
Stock up-pipes will all leak eventually. This design uses a donut gasket that allows the pipes to slide in/out of the collector during thermal cycling (expansion/contraction). This causes wear on the pipes and sooner or later they don't seal. It is generally 'sooner' after disturbing them while R&R'ing turbo...
I have deleted lots of pedestals. Some people get way too excited about this mod... Remove the big snap ring and cover and pull the guts out of pedestal. Drill/tap the hole the actuator rod came out of and install a pipe plug with quality thread sealant. Delete is done. Plug the EBPV harness back into pedestal for no codes.
Old Jun 8, 2017 | 06:35 PM
  #38
SkySkiJason
This just showed up!! I'll be prepping and ceramic coating up-pipes and this exhaust manifold tomorrow!!! (Look for KC369 Install thread).
Old Jun 8, 2017 | 06:40 PM
  #39
Eaglescout94
Is the tap I need 1/4 pipe? I thought that's what I read but can't recall off of the top of my head. I'm not supposed to get my shiny new "toy" until Monday, should be fun after I get it installed though.
Old Jun 8, 2017 | 06:49 PM
  #40
SkySkiJason
I think so! I may be doing this tomorrow. Maybe it's time for another DIY pedestal delete thread? (I need a film crew, lol)
Old Jun 8, 2017 | 08:27 PM
  #41
akcooper9's Avatar
akcooper9
Awesome, mine shows monday!
Old Jun 8, 2017 | 08:42 PM
  #42
PASSIONATE_GRANDPA
You guys are making me jealous.
Old Jun 10, 2017 | 01:03 AM
  #43
Bonanza35's Avatar
Bonanza35
Jealous for sure. Can't wait for a write up on how you like it.
Old Jun 10, 2017 | 07:30 AM
  #44
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Jason, this is the biggest of the three that may become available soon right?
I think they will be 63, 66 and 69 respectively?
Do you happen to know what injector range size the 69 serious (one that you have in your possession) is rated for?
I believe the 63 which is what akcooper9 is said to be suited for stock to 160/30 injectors.
The turbo looks great! Cannot wait to see the the pictures and hear your thoughts on the sound and performance.
Old Jun 10, 2017 | 07:36 AM
  #45
akcooper9's Avatar
akcooper9
63mm (recommended for stock to 160/30 injectors)
66mm (recommended for 180/30 to 238/100 injectors)
69mm (recommended for 250/100 to 300/200)
