Help with codes
Old Jun 8, 2017 | 12:04 PM
marv02's Avatar
marv02
I went through the same issues months ago Mine end being the ERG tube and the fitting coming off the exhaust manifold fitting after fitting the exhaust leaks from there no more codes.
Old Jun 9, 2017 | 08:14 AM
Middleagecrisis's Avatar
Middleagecrisis
Were you getting a "141 - Fuel system "lean" with high flow demand" code? I do have an exhaust leak that I cannot find, that seems to be originating around the passenger side exhaust manifold flange area. I had the exhaust manifolds bead blasted and the mounting surfaces resurfaced, so they are crack free and should be sealing. Seems to mostly go away after the engine has warmed up, but is always there. Wondering if it's coming from one of the bolt holes for the bracket mounts on the front of the head.
Old Jun 9, 2017 | 09:58 AM
subford's Avatar
subford
Note the 513 code could also be low battery voltage.
141 just means the engine is running lean. Most of the time this is low fuel pressure.
As for the 338 code:
DTC 338 indicates the engine has not reached the normal operating temperature or the system is not heating. The cooling system is not properly controlling the engine temperature.
Possible causes:
-- Thermostat stuck open.
-- Water outlet gasket leak.
-- Water pump gasket leak.
-- Head gasket leak.
-- Heater hose leak.
scoug001
Oct 17, 2008 06:32 PM
prepwd
1978 - 1996 Big Bronco
Aug 23, 2008 08:28 PM
sharktaco
Jun 3, 2006 07:53 PM
desertdave35
Jan 30, 2005 05:20 PM
May 3, 2002 01:31 AM
