EGR valve of question
I understand that exhaust runs through the EGR. what I don't know is:
Does the EGR valve control the amount of exhaust into the air intake?
If so, does only the amount of exhaust let through the valve go through the EGR?
if so, if the EGR valve is closed then no exhaust will go through the EGR?
thanks!
thanks!
Scott
The egr cooler is a heat transfer mechanism that always has coolant flowing through regardless of a lot of exauster gas or a little. If the egr cooler has not failed, coolant does not mix with intake nor exhaust gas into coolant.
if the egr valve is closed is there any exhaust gas flowing through the egr cooler?
if there is no exhaust gas flow then it seems to stand to reason there is little to no heat transfer, cooling, and therefore little to no stressing of the egr cooler component.
if there is always exhaust gas flowing through the EGR cooler regardless of egr valve position being open or closed, then there is always stress on the egr cooler.
on
The gas is always there regardless if the valve is open or closed. The gas comes from the uppipe into the cooler then to the valve in the manifold.
And all ya' gotta do (Scott speaking to himself) is look at where the damn valve is!!!
No problemo. no apology needed!
