Tie rod replacement
Old May 27, 2017 | 09:38 PM
schlepprock250's Avatar
schlepprock250
Tie rod replacement
Hey gang. I was under the truck today (late 99 cc 4x4). Having my wife turn the wheels back and forth looking for possible issues. I'm seeing some movement in the right side tie rod at the knuckle. I'm going to replace all the tie rods and I'm hoping you guys can lean me in the right direction as far as what brand is recommended. I did some searching but some of the info is a little dated so I'm looking for fresh thoughts. Thanks..
Old May 27, 2017 | 09:56 PM
F350-6's Avatar
F350-6
Moog has regular duty and a heavier duty. The regular duty sucks. XRF makes them too. While I haven't used XRF tie rods, their ball joints are top notch.
Old May 27, 2017 | 10:29 PM
Dirtscooter250's Avatar
Dirtscooter250
I used to have Moog eveeything but ball jts and tie rods seem to be failing around 50,000 or less. Last end went bad in 50,000 and the ball jts were getting play at 35,000 mi. Would like to try XRF next time! Have 130,000 hard miles on an F550 and ball jts and tie rods are original but my other trucks seem to get around less than half on front ends not sure why.
Old May 28, 2017 | 01:08 AM
ExPACamper's Avatar
ExPACamper
Subscribing. This job is on my list
Old May 28, 2017 | 06:04 AM
JeepGuy93's Avatar
JeepGuy93
Moog problem solver or OEM. Moog actually makes a front end kit for these trucks.
http://www.moog-suspension-parts.com/moog_packagedeal012
Old May 28, 2017 | 08:13 AM
cabloom300's Avatar
cabloom300
http://www.thetireclub.com/item.wws?sku=DS1439DS1438&itempk=504651&mf r=XRF?q=DS1439DS1438&safe=active
Just bought this kit and installed. They looks very heavy duty but I can't say much for how long they will last. Time will tell. They do have the million Mike warranty as well.
Old May 28, 2017 | 08:32 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That part number and link appears to be the warranty itself, not the part. Unless I am missing something.
Old May 28, 2017 | 09:38 AM
schlepprock250
I'm looking at the XRF tie rod kit at FICM, are the XRF tie rods a good solution?
Old May 28, 2017 | 12:54 PM
schlepprock250
Yeah I've decided to do a kit. Tie rods and ball joints.
Old May 28, 2017 | 02:34 PM
cabloom300's Avatar
cabloom300
Negative. It's the whole
steering kit. Here is also another link.
http://www.thetireclub.com/content.wws?fname=FORD_TRUCK_KITS.html
Old May 28, 2017 | 02:44 PM
schlepprock250
Yeah I'm looking at two different kits from FICM Repair. One ball joint kit and a tie rod kit, I was really seeking opinions on the XRF line.
Old May 29, 2017 | 07:30 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
We carry both the XRF and Moog lines, but the XRF line is far superior in every way. Stronger, beefier, no problems!
Old May 29, 2017 | 08:01 AM
Sous's Avatar
Sous
FTE Emeritus
Link to the FICM/XRF kit is below:
99-2004 Ford F250-F350 Super Duty 4x4 All models Steering Kit
Old May 30, 2017 | 01:20 PM
brian42's Avatar
brian42
Veteran: Navy
I'm very pleased with my XRF ball joints. I'm on my second "steering kit" and I went OEM on that since I wasn't overly impressed with my (then) Moog ball joints. Now that I've got some miles on my XRFs I'm going to add to my XRF inventory with steering when the 'rods go out next time. The kit is less than what I spent at the Ford parts counter with a much better warranty!
kefrko
Mar 2, 2016 02:04 PM
ligito
May 22, 2015 05:54 PM
Duke78
Jan 12, 2009 03:19 AM
94.5turbodiesel
Oct 3, 2007 07:34 PM
jjp
Mar 1, 2002 10:12 AM
