to SHIFT KIT or not to SHIFT KIT??
Old May 27, 2017 | 06:25 PM
GoldCo's Avatar
GoldCo
Exclamation to SHIFT KIT or not to SHIFT KIT??
...that is the question; what is the answer??
Just picked up a '95 E4OD (RWD) "Lightning" tranny with only 33K miles on it. (Will be mated to '95 5.8 using factory harness/PCM in a '52 F3.)
I know that "ideally" a shift kit is always a good thing, but I'm weighing the pros/cons based on the following:
1) $$ (this is a budget build)
2) this tranny is low-miles and in great shape (reportedly) as-is
3) I've never torn into an AT before and am a bit reluctant (i.e. nervous) with sooo many parts involved!
4) impatience : I've yet to fire up the rebuilt motor and am anxious to just replace the filter (which I have ready to go) and fill it with fluid (16 qts?) so I can bolt up the starter and call it good!
5) I'm not building a race truck, tho will see some "spirited" driving.
Any insight appreciated.
Old May 27, 2017 | 10:13 PM
jk080's Avatar
jk080
Transmission Rebuilder
The most beneficial part of the the shift kit for the E4OD is the upgrade to the pressure regulator assembly and the TCC function that is in the pump. So if you are going to do it be prepared to remove the pump and valve body at a minimum.
If you dont want add the extra work and are a bit impatient with getting this project running. I would just install the transmission as it is and get the vehicle moving and adjust later if needed.
1993_f350_2013
Oct 14, 2013 10:50 AM
xc4jokestomper
Mar 19, 2012 10:24 AM
Marc150
Mar 3, 2006 04:50 AM
OldRed460
Feb 7, 2006 06:56 PM
92EB-240K
1978 - 1996 Big Bronco
Aug 1, 2003 02:34 PM
