Sporadic tranny problems, temp fix= unplug battery
I have a 1999 ford ranger automatic 120k that starts to shift hard from first to second and sometimes drops from second to first for the first five or so miles then smooths out "sometimes". It progressively gets worse until i unplug the terminal and reset the computer. This technique works for about two weeks then starts all over again. I have replaced all the external sensors and still same problem. Brought it to a tranny shop and they cannot find the issue. Any suggestions?
Problem solved, the truck went through three transmissions and had pre-ignition problems. After several sensors replaced, there was only one left was about to give up. It was the maf, fixed every single problem i had. Never threw a code.
JLS TRUCK
22
06-20-2013 03:18 PM
Crazyromi
11-04-2003 08:54 AM
