1978 - 1996 Big Bronco
E4OD problems
Old May 27, 2017 | 11:57 AM
Robertsma2's Avatar
Robertsma2
E4OD problems
Got a '92 bronco throwing code 634-MLPS. Went to replace the mlps and found that the wiring terminal was different from stock. From what ive read, ford redesigned the mlps due to potential for water damage, etc.
How do i remove the old terminal and replace it with the one that came with the kit?
Thanks!
Old May 27, 2017 | 02:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
After spending a couple seconds searching on YouTube I found this:
Old May 27, 2017 | 03:00 PM
Robertsma2's Avatar
Robertsma2
Thanks, i found that video too...just trying to find out if it can be done without cutting the wires back. My kit came with a terminal without wires and the mlps. So im assuming there's a way to remove the wires from the original terminal with out cutting or breaking them and replacing it with the new terminal.
Anyone aware of a way to get the terminal to release the wires?
Old May 27, 2017 | 04:11 PM
Mark Kovalsky
Yes, you can do that. I didn't find a video for that.
On the end of the connector that plugs in there is a red plastic piece. Carefully pry that out, it's the lock that holds the pins in place.
With a very small pick, find the plastic piece on each pin that holds it in place. Carefully lift this small piece and the pin will come out of the back of the connector. The first one usually takes quite a while. Once you've done one the others take seconds.
Old May 27, 2017 | 05:49 PM
Robertsma2's Avatar
Robertsma2
Thanks! I'll give that a shot.
I pulled the red tab working on it earlier but wasn't able to locate the tabs that release the pins. Guess injust need to fish around a little more.
Old May 28, 2017 | 11:23 AM
Encho's Avatar
Encho
The Southernmost Mod
I might need to replace my connector too... Will have to take a look at that vid.
Old Jun 1, 2017 | 11:54 AM
Redark1's Avatar
Redark1
try this video. it should help.
JW1971
Apr 6, 2011 05:19 AM
fordfan66
Feb 13, 2007 09:20 PM
Watcher
Nov 2, 2004 09:01 AM
bulldogcountry1
Aug 7, 2003 06:33 PM
